Halltech Stinger
Old Feb 5, 2005 | 10:22 PM
mrgil's Avatar
mrgil
Burnout
Default Halltech Stinger
Finally I installed the Halltech Stinger I got on the GP from nate@corvettegarage.
Installation was a breeze looks and sounds great.
No Codes... No issues with rubbing hoodliner, just had to tweak it a bit.
Will post pics after I do my Baer Eradispeed and Eradispeed Plus 1 Upgrade with powder coated calipers & SS Brake lines.
mrgil
Old Feb 5, 2005 | 10:24 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Congrats on the mods
Looking forward to the pics
Old Feb 5, 2005 | 10:29 PM
BubblePuppy's Avatar
BubblePuppy
From: Si Vis Pacem Habeatis Filios Vestros, Ad Bellum Parare Modo
Could you define "tweak"? I'm considering the Halltech Stinger, but I've read in previous postings that the air bridge on the Halltech either rubs the hood or creates a "bulge" in the hood when it is closed. What did you do during installation to eliminate these potential problems?
Thanks.
Old Feb 5, 2005 | 10:35 PM
mrgil's Avatar
mrgil
Burnout
Thanks.
Tweak...
I too had the dent in the Hoodliner and I looked real close and found the new airbridge wasn't stitting tight against the radiator top cover.
To fix this I loosened both Clamps on the coupler and shoved the airbridge as far as I could toward the throttle body and retightened them I'm pretty sure the airbridge almost touches the throttle body. It now sits hard against the radiator top cover. Voila no more rubbing.
I also installed the Performance hood seal.
mrgil
Old Feb 5, 2005 | 10:41 PM
SmacZ's Avatar
SmacZ
I did mine today also from the samee GP...right before my club meeting.....
I dont know I would say it was a breeze.....It wasnt hard but lets just say I never expected a CAI to take that much effort..(I know the vararam is worse)........
Mine sits perfect as well...no rubbing that I noticed ........
Shawn
Old Feb 5, 2005 | 10:55 PM
Snidley's Avatar
Snidley
mrgil
I did mine today too. It wasn't as easy as I expected after reading the posts here, but I attribute that to the cooler weather here causing all the plastics and rubber parts to be very stiff. Except for that, it fit nice, looks good, and caused no problems during the half hour I had the car out today.
Old Feb 6, 2005 | 12:15 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
mrgil
Thats funny, Did everyone install their Halltech today?? Cause I just got done about an hour ago. I got mine during the GP as well.
I have 1 question. When I bought my car it came with the Vortex intake. That intake did "Not" use the little rubber hose thing on the drivers side at the intake. I noticed there was a hole in the filter. Does this install there?? If so, How???
It looks like I may be missing a part the went with the stock airbox.
If I dont use it, Will this mess anything up??
Old Feb 6, 2005 | 12:17 AM
sharpvet03's Avatar
sharpvet03
Old Feb 6, 2005 | 12:34 AM
Tim04C5's Avatar
Tim04C5
Here's a pic of mine installed, which I also got through the GP.
Old Feb 6, 2005 | 08:40 AM
BubblePuppy
Tweak...
mrgil
Thanks for the info...
Old Feb 6, 2005 | 09:28 AM
Dark-Knight's Avatar
Dark-Knight
Looking forward to the pics!
Old Feb 6, 2005 | 12:49 PM
mrgil's Avatar
mrgil
Burnout
Shawn
When I said it went like a breeze I meant everything went well no problems no issues of fitment and everything went exactly according to the instructions that came with it.
mrgil
Old Feb 6, 2005 | 03:17 PM
SmacZ's Avatar
SmacZ
Old Feb 6, 2005 | 05:28 PM
Dave68's Avatar
Dave68
Yes, there is a hose connector (from the OEM airbox) that plugs into the Halltech Warhead air filter. If you don't have this, you may not be able to connect that hose. You might want to pick one up at the dealership.
Old Feb 6, 2005 | 05:43 PM
n2spd's Avatar
n2spd
I love mine. My hood would not shut the first time I tried but I didn't have the smooth coupler on good enough. After some minor tweaking it worked great. Enjoy!
Old Feb 6, 2005 | 10:42 PM
mrgil's Avatar
mrgil
Burnout
It's Basically a 90 Degree Elbow
mrgil
Old Feb 7, 2005 | 01:06 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Must have been Stinger day. I did mine too. It was harder on mine since I had to drill a hole and install the down stream air temp sensor. The PITA was getting the sensor out of the stock airbridge. I finally did it, but I was sweating breaking it. Works great no probs.
To Halltech Stinger
Old Feb 7, 2005 | 09:22 AM
Chrispy's Avatar
Chrispy
Looks great! What did you guys pay in the GP? What do these typically dyno?
I am shopping for a better cold air intake and will likely do the LS6 intake/ported throttle body at the same time.
Old Feb 7, 2005 | 10:32 AM
Dave68's Avatar
Dave68
Check my sig, although it includes the Borlas that were added for their killer sound characteristics, not added HP. The Halltech adds more than 10 RWHP and for $199.00 (GP price), that's the best bang for your buck, anywhere.
Old Feb 7, 2005 | 10:55 AM
mrgil's Avatar
mrgil
Burnout
Default Halltech Stinger Install
For those of you who haven't installed it yet.
The best tip I can give you is when removing the MAF from the air box take a plastic tool of some kind or a screwdriver and pry the rubber up all around the MAF this will break the joint between the Aluminum ring on the MAF and the Rubber on the airbox. It is stuck on real good and you need to break this bond before trying to pull it off, otherwise you will be there for a long time.
mrgil.
btw my car is an '03 if that makes a difference.
