Rear vent supports?
Old Feb 7, 2005 | 10:10 AM
RatedX's Avatar
RatedX
From: Spring Hill, Florida Life is all about new beginnings;...TRY ONE!
St. Jude Donor '07-'08
Default Rear vent supports?
Does anyone have any thoghts on a simple and more importantly, less expensive fix for the warped rear vents on our cars? Maybe something that would reinforce it in some way without having to pay the outrageous price for an aftermarket bracket to do the same job...... I know we should expect to pay big bucks for anything we want to add to our car of choice, but every now and then I get a little irritated at the aftermarket's perception of our bottomless pockets........Thanks. I guess that was a "vent"....
Old Feb 7, 2005 | 10:14 AM
Cochemarman's Avatar
Cochemarman
You could always do what I do - I only look at the car when I am standing up, then I can't see that they're bent!
Old Feb 7, 2005 | 10:17 AM
RatedX's Avatar
RatedX
Yeah, but if I run over somebody, they're going to notice it right away.....
Old Feb 7, 2005 | 10:39 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Not if you catch them from behind....
Old Feb 7, 2005 | 10:51 AM
Patches's Avatar
Patches
I bought a set of the ACI fiberglass supports a month after taking delivery of my '02. The butt was already sagging. Believe it or not, a few members here have gotten GM to pay for these since they don't offer anything comparable to address the issue. Here's what mine looks like after 3+ years.
Old Feb 7, 2005 | 11:08 AM
MSGvette's Avatar
MSGvette
[QUOTE=Patches]I bought a set of the ACI fiberglass supports a month after taking delivery of my '02. The butt was already sagging. Believe it or not, a few members here have gotten GM to pay for these since they don't offer anything comparable to address the issue. Here's what mine looks like after 3+ years.
I also got mine from ACI. I bought mine a month after I got my car.
Old Feb 7, 2005 | 11:10 AM
RatedX's Avatar
RatedX
Excellent! Patches...well I guess I'll have to bite the bullet and do it.
By the way what brand of wheels do you have? and also the tire sizes? they look just like what I am looking for to go with my new torch red drilled and slotted rotors!
Old Feb 7, 2005 | 11:13 AM
RatedX's Avatar
RatedX
[QUOTE=MSGvette]
How much were the fiberglass ones? ( I'm cheap) :o
Old Feb 7, 2005 | 11:16 AM
Patches's Avatar
Patches
Supports were ~$75 if I remember correctly.
Wheels/tires are CCW 505A with 19" all around. 10" front and 11" rear widths. Tires are Pirelli P-Zero Rosso non-runflat.
275/30/19 front
305/30/19 rear
Old Feb 7, 2005 | 12:29 PM
RatedX's Avatar
RatedX
does putting 19" all around change anything important?
Old Feb 7, 2005 | 12:32 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
YES! checking account balance............
Old Feb 7, 2005 | 12:43 PM
Haven't seen anyone post about an alternative method of fixing this problem. May just have to bite the bullet and get the ones from the forum vendors.
Old Feb 7, 2005 | 12:51 PM
5JTL's Avatar
5JTL
Default Aci ?????????
Sorry, I'm a newbie to the forum. Right now, my rear sags more than the car's does but I know what's coming. Anyone got a url for ACI?
Old Feb 7, 2005 | 12:58 PM
RatedX's Avatar
RatedX
I think, first though, I will stick my head under there and study it for a while, come up with two or three good alternative ideas worthy of patents,................................ ....... then order the right ones from a supplier.
Old Feb 7, 2005 | 01:07 PM
Old Timer's Avatar
Old Timer
Half inch aluminum "U" channel cut to the approiate lengths with body trim double sided tape (black/dark grey) applied to the bottom (CLEANED) side of the "U" channel, and inside of bumper cover CLEANED THROUGHLY where braces are applied, worked just fine thank you. Just make sure that the bumper cover is very warm. If possible, pressure clamps should be applied to the bottom edge (protect outside bottom edge of cover with soft wood strip) until the bumper cover is cool. Fifteen bucks covered everything.
Old Feb 7, 2005 | 10:21 PM
RatedX's Avatar
RatedX
I believe the patent is pending!...Thanks
To Rear vent supports?
