Another paint & caliper question
Old Feb 8, 2005 | 10:23 AM
dallasvette's Avatar
dallasvette
Default Another paint & caliper question
The biggest struggle with this so far is choosing a color. I have a Black/Black coupe w/Chrome Z06 wheels. I recently replaced the rotors with the sportbrake slotted/crossdrilled ones, and ceramic pads, The red i tried just isnt dark enough. I thought a great color, deep enough for my liking would be the 50th anniversary red (Sorry, don't know the "real" name) My question is..... If I bought touchup paint from the dealer in that color would it apply easily and hold up to the "elements"????? any other suggestions?
Old Feb 8, 2005 | 10:32 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
I think you should photochop your car with the color/s you like and see which one is best. I started with the yellow and ended up doing black. IMHO, there is such a thing as too much of a good thing.
The paint designed for cals is 900 degree paint. I don't know what the heat tolerance for touch up paint would be. Might be okay for a while, but in a year it might look Just my $.02
There's another member with an red AE here with the cals painted black. My likey!
Found it for you ...
Old Feb 8, 2005 | 12:46 PM
rwlc5's Avatar
rwlc5
If you want red, get Rustoleum Sunrise Red. It is almost a perfect match for the red on the Z06 calipers. That's what I used on my Torch Red. Applied 4 coats with a small foam brush. It almost looks like it is powder coated.
Old Feb 8, 2005 | 02:19 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
Black cars need a dash of color to keep them from looking too plain. Chrome and black just aren't quite enough. Just a hint of red, yellow or even bright blue or green put some pop in your appeal.
For red calipers, Rustoleum, I believe it's sunrise red.
Old May 16, 2005 | 04:29 PM
slagrec1's Avatar
slagrec1
Not trying to hi-jack the thread ... but does anyone know if/how to get a touch up bottle of the OEM "caliper grey"? Or a close match?
FYI, one of my calipers has a couple "scrapes", courtesy of previous owner. This winter I'll re-do them to compliment the Electron Blue --right now I'd like to do a quick touch up. Advice appreciated.
Old May 16, 2005 | 04:55 PM
Zuti's Avatar
Zuti
From: Life moves pretty fast... if you don't stop and look around once in a while, you could miss it!
CI 6-8-9 Veteran
Just finished mine his weekend. Black coupe w/ C6 wheels and Sunrise Red from Rustoleum. Just make sure you clean and prime 1st if you spray. Also mask and cover the car. Zuti
Old May 16, 2005 | 04:58 PM
sailohio's Avatar
sailohio
I would have thought you'd need hi temp paint. Not? Also, what is the best way to highlight the letters in a different color?
Old May 16, 2005 | 08:53 PM
Frby98's Avatar
Frby98
I did my fronts with Rustoleum Red, just like my dad. He has had his for 2 years and no fading. I believe the heat resistance is a bunch of bunk, at least for us who don't do track time (and get the brakes to heat up a lot).
Old May 16, 2005 | 10:25 PM
Zuti's Avatar
Zuti
CI 6-8-9 Veteran
Lightly sand the letters after painting to get the metallic look, but if you want to paint a different color, small brush and patience. Zuti
Old May 16, 2005 | 10:29 PM
flyzlow's Avatar
flyzlow
An exacto knife works well too.
Old May 16, 2005 | 10:39 PM
srchief100's Avatar
srchief100
... When I did mine, I used a sanding pen on the letters, and it came out great. Less than $4 at Wal-Mart in the automotive section. A touch up paint pen is also available in just about any color you want.
Old May 17, 2005 | 12:58 AM
Stickman81's Avatar
Stickman81
St. Jude Donor '05-'06-'07-'08-'09-'10
Before painting, run a bit of "ChapStick' over the letters on the front calipers. When done, and the paint is dry, wipe off with a towel. I did have to use a razor on a couple of areas. I then lightly sanded with a foam type sanding pad with very fine grit. I then put a little clear over them.
Old May 17, 2005 | 07:17 AM
redbird2000's Avatar
redbird2000
Is this high temp paint? If not, how is it holding up?
Old May 17, 2005 | 07:22 AM
JLA's Avatar
JLA
I have the Rustoleum sitting right here and am starting the painting in a minute. I have read countless threads where people have used it and it holds up fine.
Old May 17, 2005 | 07:23 AM
jrc27's Avatar
jrc27
Cruise-In IV Veteran
Cruise-In V Veteran
I thought the calipers came in just a bare metal form??
Old May 17, 2005 | 08:39 AM
wit2pz's Avatar
wit2pz
I painted my caliper body with black hi-temp paint for grilles from Home Depot and a sponge brush.
My wife came along and painted the letters in Red with a fine brush and artists paint she bought to do my hood liner.
No problems after about 500 miles and some decent rain!
Old May 17, 2005 | 09:49 AM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Personally I like the look of the red calipers against the black car and chrome wheels. Adds a little color like Jack said.....
I used the Folio-Tek paint kit that I bought from Xtreme Motorsports.
To Another paint & caliper question
