[Z06] Polish?...
Old Feb 8, 2005 | 04:45 PM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default Polish titanium?...
I just put a set of ZO6 titanium mufflers on my coupe.
The tips need to be polished.
What's good?
Roy
Old Feb 8, 2005 | 06:11 PM
johny125's Avatar
johny125
I like FLITZ. It comes in a tube and is usually sold at gun shops. This stuff is great for a high lustre polish. Good luck.
John
Old Feb 8, 2005 | 08:15 PM
7.0sc SuperVette
Default Thanks John...
John
In Liberal SoCal It's getting harder to find a gun shop, but i definitely will track down "Flitz"
Thanks,
Roy
Old Feb 8, 2005 | 08:36 PM
Marine's Avatar
Marine
Ask a Marine. We got them right here on base, were the Liberals can't touch them.
Old Feb 8, 2005 | 10:40 PM
7.0sc SuperVette
Default Might need your help...
If things get any worse...I might have to ask you guys to store mine!
Roy
Old Feb 8, 2005 | 11:54 PM
Marine's Avatar
Marine
If it gets that bad you are welcome to stay in the extra bedroom.
Old Feb 9, 2005 | 12:49 AM
chevymetal's Avatar
chevymetal
if you cant find flitz, go to autozone or whatever and pick up some Eagle One NEVR-DULL
its usually about 4 bucks. its kinda like cotton or something when you open the can. you seriously only need a tiny bit. maybe the size of a quarter. this stuff works wonders. rub it on, and it leaves a little residue. let it sit for a few minuted and it will haze up like when you wax your car. then take a clean cloth and buff it. it will SHINE!!! it says its safe for all metals also.
Old Feb 9, 2005 | 01:28 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Thanks,
Roy
Hi 7.0sc -
Here is a link to the flitz site: -
http://flitz.com/
I see ads for it on TV -
I use NevR-Dul or simichrome paste.
best regards -
mqqn
Old Feb 9, 2005 | 02:27 AM
LuS1fer's Avatar
LuS1fer
Don't waste too much of your time. Titanium doesn't polish up as it's corrosion resistance stems from a natural oxidation of the surface which gives a dull bluey lustre but no shine.
Old Feb 9, 2005 | 03:27 AM
7.0sc SuperVette
Default Doesn't shine...
I wondered about that, I guess I'll get something to clean the grundge and not expect much in the way of appearance.
Thanks to all for the suggestions.
Roy
Old Feb 9, 2005 | 10:03 AM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Roy
Hi Roy -
The tips are not titanium and can be polished to a nice shine.
Best Regards -
mqqn
Old Feb 9, 2005 | 05:19 PM
Derf's Avatar
Derf
Ok, I don't have a Z06, I like them, but I also like a vert. They should make a Z vert. So, I bought a set of titanium exhaust from a great member of the Z06vette.net. Off a 03 w/800 miles on the set. The set is like new except for a few shipping scratches on the tips.
Question: Are the tips clear coated? What are they made of? Will power buffing take care of it. First I would use a 1000 grit wet paper.
Old Feb 9, 2005 | 05:22 PM
xsiveone's Avatar
xsiveone
I like Meguiar's all metal polish. I used it on both the stock Ti exhaust tips and the aluminum tips on the B&B exhaust.
X
Old Feb 9, 2005 | 07:40 PM
7.0sc SuperVette
Default I dunno...
If your asking me-I don't know.
Mine look a little grundgie and I want to clean them up with the proper material so I don't screw them up.
Roy
Old Feb 10, 2005 | 08:14 AM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Roy
Hi folks -
The tips on the stock Z06 setup are polished stainless - use any chrome polish you want-
I would not use sandpaper.
BTW- check out the "ON TV" section at the Flitz site I posted above - you can get a buffing ball (probably useless for the tips of exhaust due to the close proximty to the fascia) and some flitz - they also have some small sample packs for $6, with a $10 coupon for your next purchase.
best regards -
mqqn
Old Feb 11, 2005 | 02:18 AM
SLO VETTE's Avatar
SLO VETTE
to clarify (since i did a bunch of research on this topic as i was curious about it myself), the whole assembly is titanium, including the tips. the only twist is that the tips (and only the tips) are "flash coated" with chrome. it's a coating process. they will shine up beautifully with some elbow grease!
as what others have said, the rest of the assembly is oxidized titanium (which has the appearance of a duller finish), with the added benefit of being unbelievably weather & corrosion-resistant. corrosion is non-existant, basically. a blast of windex, 409 or simple green will clean them up just fine. i looked into having everything flash coated and/or polished, and discovered what a pain it would be. no thanks....
the tips will shine beautifully with any good polish and elbow grease. as others have mentioned, simichrome, mother's polish, never-dull, flitz, etc all work good. it's really just a personal preference. as for myself, i use either of the 1st two (mother's or simichrome paste polish). do not use any sandpaper, even 1k grit. way too harsh! just soap & water to clean, then use the polish.
best tip is to shine them just like you would a good pair of shoes. rub the paste with some good elbow grease on very CLEAN tips (can't be any dirt or grime on there), then wrap a real soft cotton cloth around each tip and pull back & forth quickly, just like you would shine a shoe. it works wonders!
Originally Posted by mqqn
Hi folks -
best regards -
mqqn
Old Feb 11, 2005 | 03:55 AM
TruUndrtkr's Avatar
TruUndrtkr
X
To Polish?...
Old Feb 11, 2005 | 09:38 AM
jnjboc's Avatar
jnjboc
another vote for NEVR-DULL. apparently it's been around for years. I just found it by mistake this past fall.
It's amazing. It cleans all the carbon and water vapor spots from the inside of the tips as well as getting all the road crap off the outside of the pipes/tips.
shines up reall nice to.
It is definitely safe. I use it to clean/polish my billet exhaust plate as well....
Old Feb 11, 2005 | 09:48 AM
Geneus's Avatar
Geneus
Old Feb 11, 2005 | 09:03 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Originally Posted by SLO VETTE
to clarify (since i did a bunch of research on this topic as i was curious about it myself), the whole assembly is titanium, including the tips. the only twist is that the tips (and only the tips) are "flash coated" with chrome. it's a coating process. they will shine up beautifully with some elbow grease! ...<SNIP>
Hi SLO -
Good tips - like polishing a shoe - I had never thought about it that way, but that's what I do!
I thought the tips were stainless - they are definitely spot welded in place and not just a plating - I went into the archives...
These pics show the exhuast coming off of a 2002 Z06, and clearly show the spot welds around the edge of the polished tip.
best regards -
mqqn
