I have an 01' MN6 C5. The only mod is a Corsa exhaust. Thinking about longtube headers. If my setup is just the Corsa exhaust and longtube header (and I guess I'll need a Dyno tube becuase of the headers), what kind of HP gains can I expect? Not looking to change the stock cats.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Suggest LGM longtubes, RT high flow cats and x pipe as one bundle. Then change your stock intake, get a good tune and you should realise some decent numbers - 50+ HP conservatively.
Keeping the stock cats, stock H-tube and stock intake will negate most of the gains for your $$$ spent.
I would say about 25 HP. If you change to high flow cats and X-pipe you may get a little more. This may be a low number, but I try to think in real terms. Anything above that just puts a big smile on my face. I'm just not sure I would Dyno after the headers though. That's money that you could have used for more upgrades. I'm running 340 rwhp and 347 rwtq. I have the Kook's 1 3/4 with high flow cats and X-pipe. K&N twin flow filter, 160 Therm and this is my numbers. Headers are great though.
The KOOKS headers really made a big difference for me. And I would definitely change from the stock xpipe and cats.
You guys keep saying swap the intake...Don't 2001+ already have the LS6 intake? From what I've read the LS6 intake is much better for a mildly modded car than an LSX. It makes more power down low. Am I wrong? Or by intake do you mean air filter (Vararam)??
Basically it comes down to cost. If money is no object get the full LGM setup for $1750. If you want very comparable gains go with the dynatechs for just a shade over $1200 for the full system. If you dont switch over to high flow cats you are not going to realize the most superior gains. With your corsa catback, LT headers w/ cats, an aftermarket intake, and a good tune you should be able to pull down anywhere from 35-50 more rwhp.
Getting a good tune is not just about more power. It is more importantly about making the engine run optimally. A tune is necessary to bring your A/F ratios back into a reasonable range. Running excessively rich and especially excessively lean (higher engine temps) can put stress on the engine.
They mean the air intake, not the intake manifold.
TTT
Thanks for the response but how do you pass emmissions w/ high flow cats. That's my main worry. I will definitely add the x-pipe based on the advise received. (kinda thought that would be the case.) Thanks again to everyone!
TTT
I bought an 02 Z with slp long tube headers, hi flow cats and x pipe, it has an 06 nj sticker on it, im wondering if it'll pass nj emissions
EG
Huummm.... so that's conservatively ?? So what would be your non-conservative guess ... 75 - 100 HP
EG, Are you the guy that adds up all the mods and ends up with 1,250 HP
Well... I was thinking of Braking Horsepower and not Rear Wheel Horsepower, but no matter ..
For additional RWHP, I bolt on Neon.
And Hey! Let me inform you folks that each inch of neon is worth 2.73rwhp (SAE adjusted). I've gained well over 36rwhp from the neon I've installed so far - and when I complete my stereo upgrade, I'll be good for a net gain of over 79rwhp!!!
EG
If you wrap neon all around your Vette, you could call it the Vegas Vette.
I just added Bassani 1 3/4 LT headers and hi flo cats. Before and after dyno shows 10 rwhp gain w/o tune. Not the biggest bang for your hp buck, but the sound makes up for it, it's awesome. I'll go back for a tune after intake mods.
I've been thinking about the headers and hi-flow cats too. Have you guys had any issues with leaks or codes after they've been on for awhile?
A quality set of headers, KOOKS, LGM, with new gaskets or even if the old ones are in good shape, should not leak.
High flow cats can make you throw codes however and these may need to be addressed with tuning.
I'd get it tuned Charlie to realize the most benefit from your new headers. I'll bet you are leaving a lot of performance on the table without a good tune.
As far as passing emissions are concerned, well, I will soon find out.
Icemankis and all,
is it critical to get the tune? i've been told my '99 6-speeds's computer will totally adapt and make adjustments as it learns. i have a breathless ram air intake, and b&b cat back exhaust, and am about to install a set of KOOKS LT's and magna flow cats. am at the point of paralysis by analysis. any advice would be appreciated.
