Need Help Now
Old Feb 10, 2005 | 05:32 PM
98NassauBluC5's Avatar
98NassauBluC5
From: I'm a Texan, but I traded the horse for the Vette.
Default Need Help Now
I have my wheels off of my car to paint the calipers, and I also wanted to lower it while they were off. I can seem to get the front nuts to close the space. They seem like they don't want to move, it's a 1998 model so they might have some ageing but still, what should I do? It's 4:30 right now and I need to be at work at 6. Please Help!!!
Old Feb 10, 2005 | 05:35 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Did you take the tension off the spring? I jacked up the car, put a jack stand under the spring, lowered the car onto the jack stand and turned the bolt (I guess the term would be tightened it).
Did one car a couple of weeks ago, driver's side was a bizatch. Pass. side to 15 seconds. But the spring went "Twang" when I took the tension off it or the pass. side, not the driver's side. Hope this helps.
Dave Q.
Old Feb 10, 2005 | 06:33 PM
98NassauBluC5
I didn't have enough time I'm just going to do it all over tomorrow. Anymore help or other suggestions just in case is always appreciated, thanks ya'll
Old Feb 10, 2005 | 07:57 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
You will need to remove the front wheels for adequate access to the front adjustment bolt. You may be able to get to it without removing the wheels, but it will be very difficult. Block the rear wheels, jack up one side of the front of the car and place a jackstand under the front crossmember. Remove the wheel.
You will see a 10 mm bolt, that is only accessible from the top. Turn the bolt COUNTERCLOCKWISE (as if you were loosening it). This bolt is counter threaded. If you are using a 3/8 inch drive and a socket, you will not be able to adjust it the whole way down and still be able to remove the socket. The shock will be in the way. You will need to use an open end wrench for the last part of the adjustment. You can put your finger under the a-arm to feel the gap in the bushing decrease as you adjust. You should not run the bolt the entire way to the bottom, or you will end up with a very harsh ride. Replace the wheel, retorque the wheels to 100 lb/ft. and do the same proceedure on the other side.
Old Feb 10, 2005 | 10:32 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Good to know. I am going in to put new rotors on so I am going to have a look at these. Thanks.
Stock Man's Avatar
Stock Man
Old Feb 11, 2005 | 12:02 AM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
Looks like Jackalope has you fixed up, but if you need more, PM Patches,
he has very good pics/instructions on this process! Good luck!!
I found it, this is the fronts (courtesy of Patches);
Old Feb 11, 2005 | 01:59 AM
paceace's Avatar
paceace
Did you take a cab or reassemble?
To Need Help Now
