Dyno #'s
Old Feb 14, 2005 | 01:36 PM
BBM98C5's Avatar
BBM98C5
Default Dyno #'s
Hi,
I was wondering what numbers are the dyno numbers I should be looking at, the Actual #'s or the SAE Corrected #'s? From what I understand, the SAE #'s are the ones at sea level with with perfect weather. Im I correct? Please let me know.
Old Feb 14, 2005 | 03:26 PM
Dave68's Avatar
Dave68
http://wahiduddin.net/calc/calc_cf.htm
Old Feb 14, 2005 | 03:38 PM
Mark VerMurlen's Avatar
Mark VerMurlen
I've always thought you should look at SAE numbers. The correction is supposed to make it so that you can compare numbers under different conditions. If you don't use the SAE numbers, then you can't compare your results with someone else's.
- Mark
Old Feb 14, 2005 | 03:46 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
- Mark
Dyno numbers are easily modified anyways. I'm aware of a vender who intentionally edits their number to show higher hp gains for their products on their dyno. Dyno numbers are a neat thing, but should never be counted as 100% accurate.
Old Feb 14, 2005 | 03:58 PM
BBM98C5's Avatar
BBM98C5
Ok, I was just wondering because the new SAE numbers i got on Thurs are closer to what I think the car is doing than the orig Actual #'s I got on Saturday, about 22HP more. These were 2 diffrent pulls. Thanks.
Old Feb 14, 2005 | 04:26 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
I'm curious who did your dyno work, since your sig says you're in Illinois. I had my done in Ft Wayne Indiana and then in Downers Grove Illinois a couple weeks later and the figures were within literally just a few HP of each other.
Old Feb 14, 2005 | 05:24 PM
I too would look at the SAE corrected numbers. Seems to be a more accurate way of comparing HP.
Old Feb 14, 2005 | 05:30 PM
Stangkiller
My car "stock" dynoed 342 rwhp, at a local supra shop, then on Mike Norris dyno monthes and monthes and lots of mods later at 324 before the cam.
Old Feb 14, 2005 | 08:05 PM
BBM98C5's Avatar
BBM98C5
I had a bunch of stuff (cam,supercharger, exhaust, etc...) at Extreme HP Motorsports in Elk Grove Village. He dynoed the car and had it tuned. I am happy with the car and the numbers (538RWHP corrected and 500+RWTQ) . I just got the car back about 2 weeks ago. When my new idler comes in to replace the stock one I broke, Ill be even more happy.
Old Feb 14, 2005 | 10:05 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
SAE to compare, but, it is nice to see what our cars do in the cold. Mine on the same day, same dyno went 375 SAE, 390 uncorrected
Dave
To Dyno #'s
