[Z06] Speedline Wheel Info Needed
Old Feb 15, 2005 | 02:34 PM
DRR's Avatar
DRR
Default Speedline Wheel Info Needed
Buying Z06 speedline wheels (painted) and need to know what lugs will work. Dealer says #10028615 nut and 9595118 cap. Are the lugs the same as on my '98 Vert? Then I just need to buy the caps? Thanks, Doug
Old Feb 15, 2005 | 04:54 PM
99 The Hard Way's Avatar
99 The Hard Way
Any of the C5 lugs will work as far as bolting the rim on, but you need the threaded ones to screw the lug caps onto the lug. I don't have a part #, but you should be able to just order lugs for any year Z06. Scott
Old Feb 15, 2005 | 05:29 PM
DRR's Avatar
DRR
Thanks Scott. Doug
Old Feb 15, 2005 | 09:35 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
some Z06 lugs do not have caps on them
mine is an '02 and did not come with those plastic caps
To Speedline Wheel Info Needed
