Instrument Cluster
Old Feb 17, 2005 | 08:43 PM
gltrap54's Avatar
gltrap54
Default Instrument Cluster
I have lights on my instrument cluster & audio with the key turned to accessory, but lights go out when I start the car. Anyone have this problem?
Old Feb 17, 2005 | 09:49 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Kinda simple, but is your dimmer switch turned all the way up? Not all the way till it clicks, but just before the click.
BTW, do you mean they're off when the car is running or they go off for a split second when you start the car? The latter is normal.
Old Feb 17, 2005 | 09:50 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Old Feb 17, 2005 | 10:08 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
That's about it unless you've got more info for us.
Old Feb 17, 2005 | 11:16 PM
gltrap54's Avatar
gltrap54
The dimmer switch is turned all the way up, but I lose all of my audio & instrument lights once the car is started
Old Feb 17, 2005 | 11:28 PM
metroff's Avatar
metroff
I had the same problem. Happened to me probably 3 or 4 times, and now the center part of my cluster seems to be a little bit dim. I took it into the dealership and their solution was they would replace the insturment cluster under warranty, only problem is they said the clusters were on national backorder so it hasn't been fixed yet.
Old Feb 18, 2005 | 12:02 AM
gltrap54's Avatar
gltrap54
Thanks for the input fellas............ Looks like I'm headed for the stealership without a warranty of course! Damn gotta get one of those!
Old Feb 18, 2005 | 04:04 AM
MyVetteDream
Your car is possessed. "I need an old priest and a young priest!"
To Instrument Cluster
