Aftermarket GPS Moving Map Installations.
Old Feb 19, 2005 | 05:59 PM
C5VetteLS1's Avatar
C5VetteLS1
St. Jude Donor '06-'07-'08-'09
Default Aftermarket GPS Moving Map Installations.
I'm just curious if any of you have installed a GPS Moving Map in your C5's? If so, what system did you go with and how do you like? Please post any photos you might have of the installation.
Thanks,
Richard
Old Feb 19, 2005 | 06:15 PM
scott_fx's Avatar
scott_fx
i'm using destinator laptop software with a garmin oem gps antenna. I'm actually installing it this weekend so i cant tell you how i like it yet :-)
Old Feb 19, 2005 | 06:22 PM
Shylor's Avatar
Shylor
I don't have this system but it is the one I want. I think this type of setup blends very well and could be confused as an OEM system. Plus because it doesn't pop up, it doesn't block the vent and you woudn't have to move the dash components.
Old Feb 19, 2005 | 07:19 PM
DeeGee's Avatar
DeeGee
I went with the Pioneer AVIC N1 (The N2 comes out in Spring).
I like it a lot and the nav accuracy is good. The remote is a waste of space and I wouldn't recommend that option. Some members have mounted the unit in place of the HVAC which means that the screen doesn't block the vents. I like the screen in its present position though.
Old Feb 19, 2005 | 08:49 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Originally Posted by Shylor
This is good. But what brand name is it? I like the fact that it looks like it belongs.
Old Feb 20, 2005 | 12:33 AM
redcorvette1995's Avatar
redcorvette1995
I have the Clarion Joyride in mine.
Good system.
Uses a DVD for the maps, you can drive anywhere in North America and not have to change a map disk. It also talks to you telling you when to turn and accepts voice commands. Very happy with it!
Old Feb 20, 2005 | 12:38 AM
Cambria's Avatar
Cambria
Looks like the Eclipse AVN 2454.
What did you order to start with? Did you take out the factory Nav?
Old Feb 20, 2005 | 01:47 AM
VetteramI's Avatar
VetteramI
St. Jude Donor '05-'06-'07-'10
I am going with this unit too. It gets installed on the 26th. Back in the states on the night of the 25th. The mods start on the 26th.
LIFE IS GOOD !!!!!
Old Feb 20, 2005 | 01:52 AM
c5chris's Avatar
c5chris
What is that cylindrical item on the left?
Old Feb 20, 2005 | 07:18 AM
DeeGee's Avatar
DeeGee
I didn't like the remote control mounted on the steering wheel. Too intrusive and it looked bad.
I mounted it on a flexible shaft (a flashlight) with a bracket that slides under the side of the console. It folds down out of the way when not in use or I can take it out completely.
That said, the remote is almsot useless as the voice recognition function is poor.
Old Feb 20, 2005 | 09:14 AM
makn hp's Avatar
makn hp
Default Gps
I use the Roadmate 700, can move from car to car, voice controled & it takes you to the front door.
Old Feb 20, 2005 | 10:19 AM
Speed Trap's Avatar
Speed Trap
What make and model is this unit? Looks OEM.
Old Feb 20, 2005 | 11:24 AM
Oldvetter's Avatar
Oldvetter
I agree ! I have one too, love it ! Actually use it in other cars more, but can't be beat. Make sure to upgrade the software (for free) to get map icons for gas stations, restaurants, etc. You then press an icon and it gives you directions. I have found some good restaurants that way.
Old Feb 20, 2005 | 11:43 AM
VinnyG's Avatar
VinnyG
I just had the Kenwood 915 head unit (Nav/DVD/TV) installed with the 4100 Navigation, 6 disc changer, Kenwood Music Keg, Zapco 650 Watt/6 Channel Amp, Memphis 5.25 Coaxials and Dynomated. Already had a JL Audio W7 12" Sub. I will post pics later today. I have had the Kenwood system in my 2002 Escalade for 6 months now and I can tell you from personal experiance that it is an incredibly AWESOME system.
Old Feb 20, 2005 | 05:58 PM
Shylor's Avatar
Shylor
It's the Eclipse AVN 2454. I got this picture off another forum. I think this unit looks OEM. I understand it is a tight fit that requires some slight trimming of the bezel to get the screen to fit right. The opening is only a 1.5x DIN while the unit is a 2x DIN.
Old Feb 20, 2005 | 06:07 PM
vettedevil's Avatar
vettedevil
Default http://members.aol.com/impsster/navigation
I chose the Cobra Nav-1 It has tha entire united states and Canada and nothing to load and you just plug it in to your cigarette lighter and take it in any car you want[IMG]http://[/IMG]
Old Feb 20, 2005 | 06:09 PM
vettedevil's Avatar
vettedevil
I chose the Cobra Nav-1 It has tha entire united states and Canada and nothing to load and you just plug it in to your cigarette lighter and take it in any car you want.
Old Feb 20, 2005 | 06:15 PM
garywurst's Avatar
garywurst
I have a pioneer AVIC-N1 also. I switched the climate controls and the head unit so that the center vent is not blocked. I installed this myself about two months ago and it has performed really well. I am a police officer and the map program (No GPS) we have in the patrol cars for our town is less accurate than the map software provided by pioneer.
To Aftermarket GPS Moving Map Installations.
