VIN please
Old Feb 19, 2005 | 07:00 PM
S1K C5's Avatar
S1K C5
Default VIN please
Vin 1G1YY22G7X5123088.
Old Feb 19, 2005 | 07:02 PM
NSTG8R's Avatar
NSTG8R
yes .. it's a vin number.
Old Feb 19, 2005 | 07:04 PM
RCK1999's Avatar
RCK1999
And the question is ?????????
Old Feb 19, 2005 | 07:51 PM
S1K C5's Avatar
S1K C5
LOL, can i get a VIN report Please
Old Feb 19, 2005 | 08:54 PM
WhiteC5Vette's Avatar
WhiteC5Vette
St. Jude Contributor
VIN : 1G1YY22G7X5123088
VEHICLE INFORMATION
Merchandising Model : 1YY07 Warranty Start Date : 03/24/1999
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : MILTON RUBEN CHEVROLET, INC.
3514 WASHINGTON RD
AUGUSTA , GA 30907-2948
(706) 868-0588
Selling Source : 13 - CHEVROLET
Site Code : 08270
Business Associate Code : 112501
Service Contract : Yes Branded Title : No Warranty Block : No PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 00034 LAP BELT WEBBING TWISTED N/A Closed
RC 01044 CORVETTE ELECTRONIC COLUMN LOCK N/A Closed
RC 04006 ELECTRONIC COLUMN LOCK SYSTEM 07/26/2004 Open
SERVICE INFORMATIONAL ITEMS
Vehicle Has No Current Record Of Outstanding Service Information
ON STAR AND XM SATELLITE RADIO INFORMATION
Vehicle Has No Associated On Star or XM Radio Information.
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER 03/24/1999 13 miles 03/24/2002 36013 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH 03/24/1999 13 miles 03/24/2005 100013 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 03/24/1999 13 miles 03/24/2007 80013 miles
36/36000 FEDERAL EMISSION 03/24/1999 13 miles 03/24/2002 36013 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
04/25/2003 093274 # T2020 - TOWING 48194 miles
04/25/2003 093274 # V0743 - ECL RELAY HARNESS REPLACE 48194 miles
04/25/2003 093274 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 48194 miles
10/30/2001 067900 # E5680 - CROSSMEMBER ASSEMBLY, REAR SUSPENSION - R&R OR REPLACE 35900 miles
10/30/2001 067900 # E7400 - SHAFT AND/OR SPHERE ASSEMBLY - REPLACE 35900 miles
09/08/2000 050033 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 26752 miles
09/05/2000 049888 # J0680 - TENSIONER, PRIMARY ACCESSORY DRIVE - REPLACE 26702 miles
08/29/2000 049584 # F1530 - SHAFT, AXLE - REAR AXLE - RIGHT - REPLACE 26503 miles
08/15/2000 048962 # E7125 - TELESCOPIC ACTUATOR, TILT/TELESCOPIC STEERING COLUMN - REP 26082 miles
08/15/2000 048962 # J0667 - BELT, PRIMARY ACCESSORY DRIVE - REPLACE 26082 miles
08/15/2000 048962 # B7240 - BEZEL - HEADLAMP - RIGHT - REPLACE 26082 miles
08/15/2000 048962 # B7241 - BEZEL - HEADLAMP - LEFT - REPLACE 26082 miles
05/09/2000 044440 # E7125 - TELESCOPIC ACTUATOR, TILT/TELESCOPIC STEERING COLUMN - REP 16864 miles
05/09/2000 044440 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 16864 miles
10/28/1999 036745 # N4924 - MODULE, LOCAL INTERFACE UNIT - SEAT - LEFT - REPLACE 10302 miles
10/28/1999 036745 # Z7902 - 2-DAY COURTESY TRANSPORTATION 10302 miles
10/25/1999 036560 # E7501 - LOCKING PARTS, RACK/SECTOR/LOCK BOLT/ACTUATOR ROD, STEERIN 10195 miles
10/06/1999 035846 # E7120 - SWITCH, TILT/TELESCOPIC STEERING COLUMN - REPLACE 9886 miles
10/06/1999 035846 # R0940 - SPEAKER, RADIO - I/P OR WINDSHIELD PILLAR - RIGHT - REPLAC 9886 miles
10/06/1999 035846 # R0941 - SPEAKER, RADIO - I/P OR WINDSHIELD PILLAR - LEFT - REPLACE 9886 miles
10/06/1999 035846 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 9886 miles
10/06/1999 035846 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 9886 miles
08/16/1999 033596 # E7501 - LOCKING PARTS, RACK/SECTOR/LOCK BOLT/ACTUATOR ROD, STEERIN 8432 miles
08/16/1999 033596 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 8432 miles
05/06/1999 029117 # R0940 - SPEAKER, RADIO - I/P OR WINDSHIELD PILLAR - RIGHT - REPLAC 1886 miles
04/27/1999 028714 # C4262 - SUPPORT, REAR COMPARTMENT CARGO SHADE - REPLACE 1523 miles
03/12/1999 A23088 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Gross Vehicle Weight Rating : 1700 kg (3749 lb) Order Number : BHQMFQ
Build Date : 03/12/1999 Build Plant : 1X5Y - BOWLING GREEN
OPTION CODES
AAB AG2
AK5 AQ9
BGR B34
B84 CJ2
C2L DL5
DL8 D42
FE1 FE9
F45 GU6
IL3 JL4
JL9 K63
LS1 MM6
MN6 NF2
NK4 N37
QD4 T96
UL0 UV7
UZ6 U1S
U52 VM3
V73 XGG
YGH 1AY
1SA 19I
193 86U
CLAIM HISTORY
Repair Order Date : 04/25/2003 Repair Order Number : 093274 Odometer Reading : 48194 miles
Serviced By : MILTON RUBEN CHEVROLET, INC.
3514 WASHINGTON RD
AUGUSTA, GA 30907-2948
(706) 868-0588 Selling Source : 13 - CHEVROLET
Site Code : 08270
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
05/02/2003 374 01 # T2020 - TOWING N/A N
05/02/2003 374 02 # V0743 - ECL RELAY HARNESS REPLACE 88952428 - WIRE KIT N
05/02/2003 374 03 # V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 10306414 - GUIDE KIT N
Repair Order Date : 10/30/2001 Repair Order Number : 067900 Odometer Reading : 35900 miles
3514 WASHINGTON RD
Site Code : 08270
11/02/2001 218 01 # E5680 - CROSSMEMBER ASSEMBLY, REAR SUSPENSION - R&R OR REPLACE N/A N
11/02/2001 218 02 # E7400 - SHAFT AND/OR SPHERE ASSEMBLY - REPLACE N/A N
Repair Order Date : 09/08/2000 Repair Order Number : 050033 Odometer Reading : 26752 miles
3514 WASHINGTON RD
Site Code : 08270
09/22/2000 102 01 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE N/A N
Repair Order Date : 09/05/2000 Repair Order Number : 049888 Odometer Reading : 26702 miles
3514 WASHINGTON RD
Site Code : 08270
09/29/2000 104 01 # J0680 - TENSIONER, PRIMARY ACCESSORY DRIVE - REPLACE 12559325 - TENSIONER N
Repair Order Date : 08/29/2000 Repair Order Number : 049584 Odometer Reading : 26503 miles
3514 WASHINGTON RD
Site Code : 08270
09/12/2000 99 01 # F1530 - SHAFT, AXLE - REAR AXLE - RIGHT - REPLACE 10226316 N
Repair Order Date : 08/15/2000 Repair Order Number : 048962 Odometer Reading : 26082 miles
3514 WASHINGTON RD
Site Code : 08270
08/22/2000 93 01 # E7125 - TELESCOPIC ACTUATOR, TILT/TELESCOPIC STEERING COLUMN - REP 26061673 - ACTUATOR N
08/22/2000 93 02 # J0667 - BELT, PRIMARY ACCESSORY DRIVE - REPLACE N/A N
08/22/2000 93 03 # B7240 - BEZEL - HEADLAMP - RIGHT - REPLACE 10435412 - BEZEL N
08/22/2000 93 04 # B7241 - BEZEL - HEADLAMP - LEFT - REPLACE 10435411 - BEZEL N
Repair Order Date : 05/09/2000 Repair Order Number : 044440 Odometer Reading : 16864 miles
3514 WASHINGTON RD
Site Code : 08270
05/16/2000 65 01 # E7125 - TELESCOPIC ACTUATOR, TILT/TELESCOPIC STEERING COLUMN - REP 26061673 - ACTUATOR N
05/16/2000 65 02 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION N/A N
Repair Order Date : 10/28/1999 Repair Order Number : 036745 Odometer Reading : 10302 miles
3514 WASHINGTON RD
Site Code : 08270
11/23/1999 15 01 # N4924 - MODULE, LOCAL INTERFACE UNIT - SEAT - LEFT - REPLACE 09360841 - MODULE N
11/23/1999 15 02 # Z7902 - 2-DAY COURTESY TRANSPORTATION N/A N
Repair Order Date : 10/25/1999 Repair Order Number : 036560 Odometer Reading : 10195 miles
3514 WASHINGTON RD
Site Code : 08270
11/09/1999 11 01 # E7501 - LOCKING PARTS, RACK/SECTOR/LOCK BOLT/ACTUATOR ROD, STEERIN 26061673 - ACTUATOR N
Repair Order Date : 10/06/1999 Repair Order Number : 035846 Odometer Reading : 9886 miles
3514 WASHINGTON RD
Site Code : 08270
10/22/1999 6 01 # E7120 - SWITCH, TILT/TELESCOPIC STEERING COLUMN - REPLACE 26061693 - MOTOR N
10/22/1999 6 02 # R0940 - SPEAKER, RADIO - I/P OR WINDSHIELD PILLAR - RIGHT - REPLAC 15960325 - RETAINER N
10/22/1999 6 03 # R0941 - SPEAKER, RADIO - I/P OR WINDSHIELD PILLAR - LEFT - REPLACE N/A N
10/22/1999 6 04 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION N/A N
10/22/1999 6 05 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 12457738 N
Repair Order Date : 08/16/1999 Repair Order Number : 033596 Odometer Reading : 8432 miles
3514 WASHINGTON RD
Site Code : 08270
08/27/1999 989 01 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT N/A N
08/20/1999 987 01 # E7501 - LOCKING PARTS, RACK/SECTOR/LOCK BOLT/ACTUATOR ROD, STEERIN 26050960 - LOCK N
Repair Order Date : 05/06/1999 Repair Order Number : 029117 Odometer Reading : 1886 miles
3514 WASHINGTON RD
Site Code : 08270
05/20/1999 960 01 # R0940 - SPEAKER, RADIO - I/P OR WINDSHIELD PILLAR - RIGHT - REPLAC N/A N
Repair Order Date : 04/27/1999 Repair Order Number : 028714 Odometer Reading : 1523 miles
3514 WASHINGTON RD
Site Code : 08270
05/03/1999 955 01 # C4262 - SUPPORT, REAR COMPARTMENT CARGO SHADE - REPLACE 10413530 N
Repair Order Date : 03/12/1999 Repair Order Number : A23088 Odometer Reading : 0 miles
3514 WASHINGTON RD
Site Code : 08270
03/15/1999 941 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
Old Feb 19, 2005 | 11:56 PM
ALLEGRO's Avatar
ALLEGRO
I guess that will answer about all the questions you might have !
Old Feb 20, 2005 | 12:03 AM
quick99ls1's Avatar
quick99ls1
seems like the car has been in the shop multiple times
Old Feb 20, 2005 | 12:28 AM
Cajun99's Avatar
Cajun99
That car has had some serious issues
I guess I'm lucky, mine hasn't had a single warranty repair and only one failed part.
Old Feb 20, 2005 | 01:13 AM
Vette '01's Avatar
Vette '01
Hey WhiteC5Vette can i get one of those.....
1G1YY22G015100727
Old Feb 20, 2005 | 01:15 AM
sharpvet03's Avatar
sharpvet03
Sounds like a candidate for the lemon law
Old Feb 20, 2005 | 01:46 AM
diyguy's Avatar
diyguy
Had one run on my 99 C5 MN6 when I was in for a Dealer Vette oil change special ($8.88),
Left Headlight motor replaced
Column Lock By-Pass (1st time)
Column Lock By-Pass (2nd time)
R&R left front wheel bearing
That's it!
To VIN please
