Yes, will fit/plug in but it will have the Z06 emblem (guess that's the look your after) and the redline is higher. I believe the mileage from the doner car will now appear, so that will need to be corrected.
It'll fit but I think your doing the wrong thing. Question I guess is why would you want to do this. Has yours gone south and you have access to a Z06 one?
Since he's got an FRC he's probably doing a Z06 fakey-do.
no no no....i am not doing the Z06 look-alike thing...i just really like the way those ones light up and look...i was hoping that i could take the Z06 off of it actually.
From: Piedmont, SC Currently Own: 99 Nassau blue FRC. Previously Owned: 84,95,98 Indy Pace,01 Z06
If you need your mileage programmed into a Z06 cluster, contact forum member," Pacethis ". He can program the cluster to reflect your cars current mileage.
