Z06 Tire pressure ?
Old Feb 23, 2005 | 12:31 PM
Midwest Vette's Avatar
Midwest Vette
Default Z06 Tire pressure ?
What is the factory recomended tire pressure on a Z06 ? I just put oem Z06 wheels & GY eagle f1 supercars on my 98 coupe. Mine is 30 psi with the run craps.
Thanks...........
Old Feb 23, 2005 | 12:32 PM
Avanti's Avatar
Avanti
30 psi
Old Feb 23, 2005 | 12:39 PM
Midwest Vette
Thank you very much!!
Old Feb 23, 2005 | 02:04 PM
vetdude's Avatar
vetdude
...and make sure you use GM-approved Z06 air!!! Standard C5 air will not work in Z06 tires, even thought the pressure is the same .
Old Feb 23, 2005 | 02:22 PM
viper punisher's Avatar
viper punisher
Old Feb 23, 2005 | 04:56 PM
Midwest Vette
Yes, I did buy the Z06 air. That stuff is sure expensive!!!
Old Feb 23, 2005 | 05:18 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Or, you could just buy a TAB (Tire Air Bypass) kit.
It tricks the car into thinking the correct Z06 air is in the tires, and allows you to use any type of air in the tires...even Ford air.
Old Feb 23, 2005 | 07:33 PM
Midwest Vette
That is good to know!
Old Feb 23, 2005 | 10:11 PM
30 psi cold. It should be on a sticker on the drivers door jamb.
Old Feb 23, 2005 | 10:13 PM
GrayC5's Avatar
GrayC5
Z06 Tire Loading Label:
Old Feb 23, 2005 | 10:15 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Originally Posted by GrayC5
do you agree that the sticker is on the door , or the correct air pressure is 30psi????
only one of these is correct.
To Z06 Tire pressure ?
