What's your pressure?
Old Feb 25, 2005 | 07:03 PM
Cruncher's Avatar
Cruncher
Default What's your pressure?
Today in stop and go traffic, I had the opportunity to keep track of my oil pressure. At idle, it was 33 psi. At a steady 50 mph, it was 45 psi.
I am using a K&N oil filter. What's your pressure reading at idle and at 50 mph & what filter are you using?
Old Feb 25, 2005 | 09:31 PM
Your numbers sound about normal. Mine is about the same.
Old Feb 25, 2005 | 09:36 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
good to go...
Peace
Willfulone
__________________
..................Click for
Old Feb 25, 2005 | 09:53 PM
ZOOOM's Avatar
ZOOOM
With the garage at 45 degrees, on start the pressure is 55/60 LBS. When warm the pressure is 47/50. At high RPM the pressure is 70/80 when cold... drops to 50/60 when warm...
ZOOOM
Old Feb 25, 2005 | 09:54 PM
400hp's Avatar
400hp
Mine runs about the same.
Old Feb 26, 2005 | 01:49 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
With the above.
Old Feb 26, 2005 | 01:56 AM
GrayC5's Avatar
GrayC5
As others mentioned, your pressure readings look quite normal. Your readings also can vary with different brands/types of oil filters.
To What's your pressure?
