LT Header Install Question
Old Feb 26, 2005 | 11:43 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Default LT Header Install Question
Can LT Headers be installed in the garage with the car up on ramps and stands...
Peace
Willfulone
__________________
..................Click for
Old Feb 26, 2005 | 11:53 AM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Yes, but you are going to have to get some heavy duty jack stands that will extend up to about 20 inches off the ground. check JMX's turtorial at LS1HOWTO.COM. He does the whole installation using jack stands
Old Feb 26, 2005 | 12:01 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
It can be done....and yeah you need to get the car up there
Old Feb 26, 2005 | 12:06 PM
400hp's Avatar
400hp
I used 4 jack stands. I also had the front tires on Rhino ramps and the rear tires on 10" X 10" lumber that I used to rest the keel of my boat on. That car wasn't going anywhere. I wasn't about to get squashed for a set of headers.
While I was at it, I did my oil change, new plugs, and checked out everything under the car.
Old Feb 26, 2005 | 12:43 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Good luck and be careful.
Old Feb 26, 2005 | 01:33 PM
vettenuts's Avatar
vettenuts
Did my QTP's laying on the ground, but I also have carpet in my garage so it was nice and comfy
I blocked the car using the wood blocks the boat yards use. I don't trust jack stands since my Suburban almost came down on them. I had to have the car up about 20" from bottom of the car to the floor to get them in. Other brands may be different.
Old Feb 26, 2005 | 02:11 PM
C5 KIDD's Avatar
C5 KIDD
i installed my LG's in the garage. no big deal really, but the front has to come off the ground pretty high. you also have to have the rear elevated so you can get the front up as high as you need to.
Old Feb 26, 2005 | 06:14 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
Of course. I don't know which headers you are planning to install
I installed my KOOKS headers, by myself on ramps and jackstands. You don't have to raise the car any more than the height of the ramps. The KOOKS go in from the top.
According to LS1howto.com, you'll have to raise the car up pretty high to get the LGs in. 18-20 inches in the front as the one goes in from underneath the car.
Be safe, especially if you intend to crawl under work on a car sitting on jackstands raised to such a height .
Old Feb 26, 2005 | 10:08 PM
Best of luck with the install.
To LT Header Install Question
