1) I have read on a couple of websites that the Z06 has a slower top speed than the regular coupe. Is this due more because of the body style or gearing?
2) What will the top speed be of a Z06 with 400 rwhp?
It's strictly a gearing issue. Both cars reach top speed in 5th gear at the rev-limiter setting. The standard C5 manual 5th gear ratio is .74 the z06 is .84. assuming that you have a stock rev-limiter setting and OEM tires you're looking at a top end of about 172. Additional horsepower will not change your top end in 5th gear without changing the rev-limiter setting. You don't have enough horsepower to pull max rpms in 6th gear.
If aftermarket tires were installed and the speed limiter was removed, could a Z06 top out at over 180 mph with 400+ rwhp?
StoCK,
with a stock valve train you can't get away with raising the rev-limiter much above the factory setting of 6600. In theory, a 7000 limiter setting with a 26" tire diameter will give you 188 mph but I doubt if 400 rwhp would be enough to get you there. Drag increases with the square of the velocity so it takes a lot of horsepower to go from 175 to 180. Here's a web site to compute this stuff yourself: http://www.smokemup.com/
This seems at odd's with what Dave Hill says. On the "other" forum they have a "ask Dave Hill a question" section. Here is an exact quote from Dave Hill on this very issue
" CF: Given that the C6 and C6 Z06 will be fastbacks, is there any possibility a notchback might be introduced later in the model run as it was with the C5?
Secondly, since an auxiliary hardtop for the convertible offers a similar appearance, is any thought being given to introducing such a piece, either as an orderable option or as part of the Genuine Corvette Accessories program?
DH "The notchback body style was stiff and light, but inferior for aerodynamic drag and therefore, top speed. We have no plans for its return at this time.
"We have evaluated the addition of a removeable hardtop for the convertible and concluded it is not a place we wish to spend our energy at this time. We have improved both the stiffness and quietness of the 2005 convertible, while making the manual top version even lighter than its predecessor. So we don't think the customer gains very much, and those who engage in wheel-to-wheel competition will probably prefer one of the coupe models."
AFVETTE,
Far from me to argue with Dave Hill, however it's a fact that the top speed of a stock Z06 is limited by the factory rev-limiter setting. It's also true that the fixed roof coupe (Z06) aerodynamics are inferior to the standard C5. If you put a MN6 transmission (with the higher gearing) in a Z06 I'd bet good money that the extra 55 horsepower and the higher limiter setting would overcome the slight handicap in drag coefficients. I believe the stock LS1 limiter is set at 6200 rpm.
I think the top speed issue is a moot point. Most ppl cant take a 120 mph run for more then few sec on the road race circuite.
There have been several times I have taken students down a long straight on a circuite and they freak out when the car hits 120-125 and they have to HOLD THAT speed. It takes driving skill and know how to make safe runs at those high speeds.
Be safe guys, dont do these runs on public roads. Take it to a HPDE or track day on a closed circuite for saftey. Then you dont have to worry about someone pulling out in front of you on the cell phone or whatever.
I believe the PCM settings for the rev limiter are disabled when in 5th gear. If so, then the top speed is purely torque limited. Basically you need more torque to go faster.
The reason a coupe has a higher top speed than a Z06 is due to aerodynamics of the body styling. If you put the LS6 in a coupe you would get an even higher top end, not much but a little more.
The comments on the 5th gear ratios are correct. I've had friends hit upper 180s on the bottle. Redline is your limit in 5th gear. I really wish the Z tranny had the coupe's tranny 5th and 6th ratios.
I agree with this 100% who cares if the car goes 180. I can cruise at 120 but anything above that things are going ridicously fast. Also on a public road you go to jail providing you don't hit a bump or gravel and kill yourself. Not that I haven't been lucky and had some high speed runs in my WS6 and TA. But I think I've had the vette to 110 on the highway and that was mostly on accident I looked down and was like ohh ****!!!
The coupe from what I remember will hit 175mph while the Z06 will hit 172, it's all about aerodynamics at those speeds. However the coupe takes longer to get there than the Z06.
I topped my Z out last fall on a deserted interstate very early on a sunday morning, I don't recommend anyone doing that on a public road. Then again the only real place you can do it and not go to jail would be Bonneville or something. I don't know of a single Racetrack in the US that would have a long enough straight for these cars to hit top speed (in stock form, and a track normal people can drive on).
