finally lowered it
Old Mar 3, 2005 | 02:20 PM
DEALER1's Avatar
DEALER1
Default finally lowered it
[/quote]
Old Mar 3, 2005 | 02:22 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
That looks awesome!!
Is that stock size wheels? And is that on stock bolts?
How did you get it so low? Cut bushings??
Mine went down a little with max stock bolts - but nowhere as low as yours!!
EG
Old Mar 3, 2005 | 02:23 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
Is that just on factory bolts? Looks lower than that.
In this shot it looks like your windshield is cracked to pieces
Old Mar 3, 2005 | 02:26 PM
DEALER1's Avatar
DEALER1
Its at my dealership. The reflections on glass are from streamers above.
The wheels are 19 front and 20 rear.
Fronts bolts removed and rear bushings cut.
Old Mar 3, 2005 | 02:27 PM
3318C5's Avatar
3318C5
EG
100% Looks amaizing!! How did you do it?? Mine is also not near as low as that. I used the stock bolts....
Old Mar 3, 2005 | 02:28 PM
NXTFAZE's Avatar
NXTFAZE
Damn...those look nice. Got mine dropped also, so i knew yours had to be atleast 19's......
Lookin' nice, clean, and mean......
Old Mar 3, 2005 | 02:29 PM
0EG@EnglandGreen
Supporting Tuner
Ahhhhh, that explains it. It looks soooo
That's how I want mine to look, but I have stock rims/tyres but I have the rear bolts and I'm removing the front bolts. Hope it drops as far as yours!!
EG
Old Mar 3, 2005 | 02:31 PM
BowtieDiva70's Avatar
BowtieDiva70
[QUOTE=DEALER1]Its at my dealership. The reflections on glass are from streamers above.
Whew! I too thought your windshield was cracked! Your car does look incredible!
Old Mar 3, 2005 | 02:32 PM
Lithium's Avatar
Lithium
looks really
Old Mar 3, 2005 | 02:35 PM
3318C5's Avatar
3318C5
EG
You can remove the front bolts completely??
Old Mar 3, 2005 | 02:42 PM
DEALER1's Avatar
DEALER1
https://www.corvetteforum.com/techti...D=90&TopicID=1
Old Mar 3, 2005 | 03:00 PM
0EG@EnglandGreen
Supporting Tuner
You can follow the tech tip (which is very well written with pictures) or you can do what ALLKAR suggests here.
If you have seen ALLKAR's C5s, you will have a new appreciation of l-o-w. He is using coilovers to get that low though.
But for stock suspension - this is courtesy of ALLKAR:
" You have a couple of choices. If you don't want to reuse the bolts, you can lift the spring off the A-arm and use a hacksaw blade to cut the bushing off the bolt then unthread the bolt out of the spring. To remove the bolts you'll have to remove the calipers, lower shock mounts, sway bar mount, and spindle from A-arm or upper A-arm mount. Then remove adjusting bolt. I did the latter. I used a couple of layers of Dyna Mat between the A-arm & spring. Any kind of heavy rubber will work. I had no noise, and the ride was fine. (It will be stiffer). I would also suggest you get a set of Bilstein shocks. They are 1" shorter and will give you a little more travel, and help the ride quality. Get 1/2" x 6.5 or 7" Grade 8 bolts & nylon lock nuts for the rear.
Al"
Old Mar 3, 2005 | 03:07 PM
Nates99ss's Avatar
Nates99ss
DAYUUM! Good lookin ride!
Old Mar 3, 2005 | 03:20 PM
DEALER1's Avatar
DEALER1
Thanks for the compliments.
Old Mar 3, 2005 | 03:24 PM
yellow01's Avatar
yellow01
Looks good man!!
How in the world do you guys with cars that low drive around?
I've got mine down to about 3 fingers over the tire and I rub the front EVERYWHERE. Just getting out of my driveway makes me cringe (just the rubber chin spoiler but still).
I don't imagine you could even clear a speedbump without high centering.
Old Mar 3, 2005 | 03:35 PM
TruUndrtkr's Avatar
TruUndrtkr
yeah ....that looks hot..super low
Old Mar 3, 2005 | 03:45 PM
0EG@EnglandGreen
Supporting Tuner
Originally Posted by yellow01
Looks good man!!
I'm at 3 fingers on stock bolts and I never touch anywhere (I'm in CT), and I have 6 speedbumps here at work. That's why I want mine lower
Doesn't Dealer1 car look awesome?
To finally lowered it
Old Mar 3, 2005 | 04:04 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
The drop on that car looks badd a$$$. but remember the wheels are bigger.
That car does look sweet DEALER ...
Old Mar 3, 2005 | 04:06 PM
Vetteran's Avatar
Vetteran
St. Jude Donor '03-'05-'06-'07
You didn't lower it, your slammed it!! Looks great!!
Old Mar 3, 2005 | 04:20 PM
ORANGEBROTHERS's Avatar
ORANGEBROTHERS
[/QUOTE]
Looks great, are your tires rubbing the fenders when you hit pothole? How does it ride compared to stock? Can you go over speed bumps without bottoming out?
Just some concerns I have since mine is a daily driver.
