Radiator support
Old Mar 4, 2005 | 10:38 AM
showem's Avatar
showem
Default Radiator support
I am changing out my radiator support today from the factory installed to a KEWL custom painted support.
I do belive it will be an easy installation but any advice will helpfull. Besides it is a good reason to bring the car out of mothballs for a while as temperatures should hit around 60 today
Old Mar 4, 2005 | 11:00 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Yes, it will be easy. Unplug and remove your airbridge. You will than have four 10mm bolts to remove. That's it. You may be able to just disconnect the airbridge from the Tbody but since you are putting in painted stuff I would just remove it and not take the chance of scratching the new piece while sliding it under.
Old Mar 4, 2005 | 11:22 AM
showem's Avatar
showem
Thanks for the info. I will do exactly that as I do not want to scratch the paint
Old Mar 4, 2005 | 12:39 PM
The job is pretty easy, but it would be easier if you had a helper when you get ready to install the painted part, simply to keep it from getting scratched.
Old Mar 4, 2005 | 02:40 PM
showem's Avatar
showem
Thanks guys all done. I did do it myself wasn't to hard. Hey JDs00PewterCoupe maybe I will see you at vettes on the square in Independence we have been there 2 years now and have a great time.
To Radiator support
