Dumb question concerning dynos.....
Old Mar 4, 2005 | 09:55 PM
RatedX's Avatar
RatedX
From: Spring Hill, Florida Life is all about new beginnings;...TRY ONE!
St. Jude Donor '07-'08
Default Dumb question concerning dynos.....
OK, I have never had my car on a dyno, Heck I've never even SEEN a dyno; but one thing I've always wondered is this:
How can an acurate hp reading be given when there is no air blowing in through the intake? does that not increase hp? or is that taken into account through the programming?
Told you it was dumb! :o
Old Mar 4, 2005 | 10:04 PM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
Not a dumb question and hence the reason there are so many thread debates over which intake is the best. There is also a recent debate on the AFR on the dyno vs on the street. So tuning on the dyno produces horsepower that you might not see at the track. Buttt, in defense of the dyno, it gets you close and realize with like the Varaam (sp) you will achieve more horses on the track.
Jim K.
Old Mar 4, 2005 | 10:14 PM
RatedX's Avatar
RatedX
So then, apparently it's just a rough gauge of true hp and not the absolute standard that some folks make it out to be.
Thanks!
Old Mar 4, 2005 | 10:21 PM
BowtieDiva70's Avatar
BowtieDiva70
No two Dyno test will read the same. Even back to back runs will give a slightly different results - let alone when you try to compare readings at one shop to another day at another shop. Dynos do try to correct for temperature, relative humidity and air pressure, but they are not perfect.
The most important use of a dyno run is to establish your base values (usually the average of two or three runs), make your changes and note the results. You can then compare to see the change .
Good luck and have fun
Old Mar 4, 2005 | 10:24 PM
gairno's Avatar
gairno
You said that there is know air flowing to the mass air sensor. What they do is put big fans in front of the car to give you the air as if your driving down the street. One thing though, you can dyno at one shop and then dyno at another shop and have two different readings. That has to do with the person that is doing the dyno. My car dyno'd at 339.19 rwhp and 347.46 rwtq.
Old Mar 4, 2005 | 10:27 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
There are also different types of chassis dynos and they should be calibrated for accuracy. So the same car can put down diferent HP numbers on diferent dynos on the same day. Some people use a large fan in front of the car to help keep it cool so simulate if it was moving on the road.
Old Mar 4, 2005 | 10:32 PM
RatedX's Avatar
RatedX
[QUOTE=gairno]You said that there is know air flowing to the mass air sensor. What they do is put big fans in front of the car to give you the air as if your driving down the street.
AHHH!... Well like I said I've never even seen a dyno.......Thanks everyone
Old Mar 4, 2005 | 10:48 PM
Dark-Knight's Avatar
Dark-Knight
Thanks!
Yep, and there are other variances such as temperature, air pressure and humidity.
Old Mar 5, 2005 | 01:27 AM
Bill Dearborn's Avatar
Bill Dearborn
The DynoJet is accurate to within +/- 1%. That means with a 300 horsepower reading you could really have 297 or 303. That is why there is some variation between back to back runs. The only way to establish a baseline is to make several runs and average their readings then make your changes and make the same number of runs again and average their result.
Bill
Old Mar 5, 2005 | 01:30 AM
Automag928's Avatar
Automag928
....and on top of all that there are different brand dynos, some loaded, others unloaded...
To Dumb question concerning dynos.....
