Parking Brake ?
Old Mar 5, 2005 | 12:48 PM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
Default Parking Brake ?
I need a quick tip. Which way to turn the star adjuster to expand the shoes? Thanks.
Old Mar 5, 2005 | 06:16 PM
tdahl's Avatar
tdahl
Against the detent if you can move the wheel in a direction, it needs to go the opposite, and you would need to use a small screwdriver to allow the wheel to move while you hold the detent out of the way...... follow? make it so you cant get the rotor on.... then back it off two or three clicks... (ET's directions)
