Get two pair and use your floor jack to set the car on the ramps. Great for working under the car.
I have 4 ramps and put the whole car up on them anytime I do work. Less chance of a jack slipping and I feel much safer under the car. Also makes oil changes easier....
Will Rhino ramps give enough clearance to install a cat-back exhaust system?
I put my stingers on with the front on rhino ramps, and the back up higher with jackstands under the frame rails. Had to cut the old system off though.
