Vortex Users Only
Old Mar 11, 2005 | 07:13 PM
Ken1234's Avatar
Ken1234
Default Vortex Users Only
Ok Vortex users, tell me what you think about Vortex. I installed mine, like it alot, and installed Corsa Exhaust too. I ran 8.35 / 83.45mph at the 1/8 last weekend with my A4, and Traction Control on (big mistake on this). I never ran it before, but I thought the time was ok, and I have the 2.73 gears.
I've heard alot about Vararam, but lets hear some from the Vortex users. Let me know.
Old Mar 11, 2005 | 07:18 PM
ANTIVINUM's Avatar
ANTIVINUM
I have the same setup on my 99 MN6 and ran a 12.90 at 112 mph with a 2.06 60 ft. But I am going to get a vararam when I found some $
Old Mar 11, 2005 | 08:16 PM
Ken1234's Avatar
Ken1234
Why do you believe the Vararam will give you more than Vortex?
Old Mar 11, 2005 | 08:18 PM
scott_fx's Avatar
scott_fx
I hydrolocked my engine with the vortex...just be careful when you hit a puddle. :-(
Old Mar 11, 2005 | 08:20 PM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Had mine since Xmas of 99, no problems, works great!!
Old Mar 11, 2005 | 08:27 PM
Ken1234's Avatar
Ken1234
You have had yours since 99 and no problems. Do you believe a Vararam is that much better than the Vortex? I don't believe it to much different. I think it's more the driver.
Old Mar 11, 2005 | 09:58 PM
97C5ENVY's Avatar
97C5ENVY
I had my vortex since May 2000 and have had zero issues. About the only thing the vararam will get you (over the vortex) is more air charge at high speeds....so you have to ask yourself - is the vararam worth all the extra $$$ for the last few seconds of the 1/4 mile track. And if you only have an 1/8 mile track in your area then don't even bother with the vararam. Just my $.02.
Old Mar 11, 2005 | 10:11 PM
CNB's Avatar
CNB
What I don't like about the Vortex is that it sits directly above the radiator and when the car is stopped it sucks in hot air. Other then that I like it. I think the Vararam has the advantage because it always takes cooler air from outside the car. I'll probably have the Vararam installed on Monday and I'll let you know if I can feel a difference.
Old Mar 12, 2005 | 12:16 AM
Mitch C's Avatar
Mitch C
Several members have hyro locked their engines with the Vortex. All cold air intakes are more prone to hydro lock than non cold air intakes. However the Vortex is a bottom breather that is more likely to cause hydro lock if you run thru a deep enough puddle of water.
Old Mar 12, 2005 | 01:44 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Well, I don't think is is that much better, it's just a choice. Claims by both are more than they actually produce, horsepower wise. If you drive fast through a 2-3 ft standing lake, you will get the same results. Ouch!!
Old Mar 12, 2005 | 02:41 AM
50 4Ever's Avatar
50 4Ever
Wil Cooksey #256
I have had the Vortex for two years (37,000+ miles) and have had no problems. I was a little concerned when driving through a very bad thunderstorm in Kentucky last summer. The highway had at least 1" of water on it, it was raining so hard the wipers could not even begin to keep the windshield clear.
I love the Vortex and haven't considered switching to Vararam.
Old Mar 12, 2005 | 07:33 AM
WKMCD's Avatar
WKMCD
Vortex..Great SOTP results - no problems Also run Indy's with x-pipe.
Old Mar 12, 2005 | 10:08 AM
rodknock's Avatar
rodknock
Vortex 99 coupe three years no problems.
To Vortex Users Only
