Man does she shake...
Thanks!!
As for this car, it could be bad gas, bad ground in the wiring harness, bad plug or wire (or both) or maybe problems with the valves. (Although I haven't heard of problems with the LS-1 and oil blow by, it is a possibility.) I would have it checked out by a mechanic before buying it. Have them run a diagnostic on it, check compression, etc... It's worth the $$ to know what you are dealing with.
If the vibration was there all the time throughout the RPM band, I would look at the torque tube/connections. I believe there are rubber isolators that can go bad on it, but I haven't experinced this and it's just a guess on my part. I'd also check motor mounts, but again, if the engine is running smoooooth, then a bad motor mount wouldn't be as obvious until you put the engine under load. (Step on it.)
Just my .02 worth.
Regards,
Mark
Just my .02 worth.
Regards,
Mark
Anyhow.... the vin# is 1G1YY22G6Y5116652 if anyone can give me some hist. on the car.. I would be ever so thankful!
VEHICLE INFORMATION
Merchandising Model : 1YY07 -2000 CORVETTE COUPE Warranty Start Date : 01/31/2000
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer : PURIFOY CHEVROLET CO.
PO BOX 165
FORT LUPTON , CO 80621-0165
(303) 857-6665
HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
08/23/2004 506012 # V1153 - 04006 - INSTALL HARNESS KIT - AUTOMATICS ONLY 53921 miles
06/09/2003 160145 0 F1531 - SHAFT, AXLE - REAR AXLE - LEFT - REPLACE 35974 miles
06/09/2003 160145 0 L1200 - SENDER AND/OR PUMP ASSEMBLY, FUEL (TANK UNIT) - REPLACE 35974 miles
06/09/2003 160145 0 N4000 - ELEMENT AND/OR ****, CIGARETTE LIGHTER - REPLACE 35974 miles
04/16/2002 408971 # C0182 - REGULATOR, FRONT DOOR WINDOW - RIGHT POWER - R&R OR REPLAC 27455 miles
10/12/2000 019742 # N2320 - SWITCH - IGNITION - REPLACE 11607 miles
10/12/2000 019742 # Z7903 - 3-DAY COURTESY TRANSPORTATION 11607 miles
10/12/2000 450417 # T2020 - TOWING 11607 miles
09/20/2000 304206 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 9842 miles
09/20/2000 304206 # Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 9842 miles
09/20/2000 304206 G Z5000 - DEALER/RETAILER TRADE(PART OBTAINED LOCALLY) 9842 miles
09/20/2000 304206 # Z7904 - 4-DAY COURTESY TRANSPORTATION 9842 miles
09/12/2000 303347 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 9714 miles
09/12/2000 303347 # Z7906 - 6+ DAY COURTESY TRANSPORTATION 9714 miles
08/10/2000 300184 # R4490 - TRANSMITTER, REMOTE DOOR/REAR COMPARTMENT LOCK - REPLACE 8025 miles
07/18/2000 297590 # F2143 - CARRIER ASSEMBLY (COMPLETE) - REAR DIFFERENTIAL - REPLACE 7322 miles
07/18/2000 297590 F Z7200 - CORPORATE PARTS RETURN REIMBURSEMENT 7322 miles
07/18/2000 297590 # Z7910 - 1-WAY SHUTTLE COURTESY TRANSPORTATION 7322 miles
05/30/2000 386411 # N3231 - ACTUATOR ASSEMBLY - HEADLAMP - LEFT - REPLACE 4758 miles
01/07/2000 516652 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
VEHICLE BUILD
Gross Vehicle Weight Rating : 1664 kg (3669 lb) Order Number : CCHX6Q
Build Date : 01/07/2000 Build Plant : 1Y5Y - BOWLING GREEN
OPTION CODES
AK5 - DRIVER & PASSENGER SUPPLEMENTAL INFLATABLE RESTRAINT SYSTEM AR9 - BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT B34 - COLOR-KEYED FRONT FLOOR MATS, CARPETED INSERTS
B84 - BODY SIDE MOLDINGS CF7 - REMOVABLE SUN ROOF
C60 - AIR CONDITIONING DL5 - ROADSIDE SERVICE INFORMATION DECAL
DL8 - HEATED REARVIEW MIRRORS FE1 - SUSPENSION SYSTEM-SOFT RIDE
FE9 - FEDERAL EMISSIONS G90 - REAR AXLE-3.15 RATIO
G92 - PERFORMANCE AXLE RATIO IP3 - TRIM INTERIOR DESIGN - AR9
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM K63 - 110 AMP GENERATOR
LS1 - 5.7L LITER SFI, V8 MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF2 - FEDERAL EMISSION SYSTEM, TIER 1
NK4 - LEATHER WRAPPED STEERING WHEEL QD4 - STYLED ALUMINUM WHEEL
R9Z - POMS EXPEDITE - SOLD ORDERS T82 - TWILIGHT SENTINEL
T96 - FOG LAMPS UN0 - AM/FM STEREO W/CD PLAYER
UV7 - WINDSHIELD ANTENNA UZ6 - BOSE SPEAKER & AMPLIFIER SYSTEM
U52 - ELECTRONIC INSTRUMENTATION VM3 - CONSUMER INFORMATION LABEL
V49 - LICENSE PLATE FRAME V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT TIRE-P245/45ZR17 BW SBR YGH - REAR TIRE-P275/40ZR18 BW SBR
1SA - OPTION PACKAGE - BASE 19I - INT EBONY INTERIOR TRIM
193 - BLACK LEATHER TRIMMED SEATING SURFACE 41U - BLACK
PO BOX 165
(303) 857-6665
HISTORY
VEHICLE BUILD
OPTION CODES
PO BOX 165
(303) 857-6665
HISTORY
VEHICLE BUILD
OPTION CODES
