Normal Engine Temp??
Old Mar 16, 2005 | 10:20 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Default Normal Engine Temp??
What is the normal engine operating temp.... in trafiic and....on the highway?
I have a 98 coupe and according to the gauge it us running at 200 to 220 degrees. Is this "normal"? Should I change the T-stat?
Mark
Old Mar 16, 2005 | 10:21 PM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
this is normal, and yes ou can change it if you like. I changed mine and noticed a huge improvment in consistencies at the drag strip.
Chris
Old Mar 16, 2005 | 10:23 PM
towercontroller's Avatar
towercontroller
Yes. I live in the DFW area and last year mine was 220-230. Changed to a 160 stat and LS1 edit now im around 180.
Old Mar 17, 2005 | 01:11 AM
FLACHUSNRET's Avatar
FLACHUSNRET
St. Jude Donor '11-'12-'13-'14-'15-'16
If you will run your A/C it will cause both fans to run thereby keeping your temp 190-210. If not running A/C your fans don't come on until around 230 degrees.
Old Mar 17, 2005 | 06:13 AM
Mitch C's Avatar
Mitch C
Chris
Old Mar 17, 2005 | 08:46 AM
Blue Lion's Avatar
Blue Lion
Mine is around 190 most of the time.
Old Mar 17, 2005 | 09:22 AM
Ron H's Avatar
Ron H
Put in a 160 stat this weekend, it now runs in the 170 to 180 area.
Old Mar 17, 2005 | 09:24 AM
hawki's Avatar
hawki
To Normal Engine Temp??
