Which air filter?
Old Mar 17, 2005 | 12:41 PM
YBNORML's Avatar
YBNORML
Default Which air filter?
Which air filter would you people say is the better replacement for my 2000 A4, K&N or Fram air hog? Or does it even matter?
Thanks in advance for the imput.
[IMG][/IMG]
Old Mar 17, 2005 | 12:57 PM
I'd get a Blackwing or Stinger - but that is just my opinion.
Old Mar 17, 2005 | 01:12 PM
dbirdhouse1's Avatar
dbirdhouse1
I use the K&N...having said that, doubt it matters with a stock replacement........
Old Mar 17, 2005 | 01:17 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Stick with a paper OEM for a stock filter.
Old Mar 17, 2005 | 01:22 PM
MAC5's Avatar
MAC5
Unless your going to install an aftermarket filter system seems like just replacing the ACDelco is a very good alternative. I've had a K&N drop in, WIX and Delco, and honestly can't tell the difference. Have seen some recent articles on the forums that the ACDelco provides best airflow and protection.
Old Mar 17, 2005 | 01:26 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Filters better than K&N and such (been proven, search) You not going to get 10hp from a panel filter. Maybe 5 from a blackwing type, but is it worth the 300 smackers, you decide.
Old Mar 17, 2005 | 01:32 PM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
K & N's are cheaper in the long run, but don't believe the hype. I'm sticking with A/C Delco.
Old Mar 17, 2005 | 03:34 PM
YBNORML's Avatar
YBNORML
Thanks all, I appreciate the feedback!!
Old Mar 17, 2005 | 05:58 PM
66427-450's Avatar
66427-450
agree 100%.......
unless your engine is highly modified, the only significant change you'll get with the oiled filters in more sand thru your engine. I went with the std. Fram CA3914
Old Mar 17, 2005 | 06:01 PM
C5 RACNG's Avatar
C5 RACNG
stock paper filter w/ ZO6 lid
Old Mar 17, 2005 | 08:07 PM
Blue Lion's Avatar
Blue Lion
I have a K&N, Z06 airbox that I drilled out even more, and a smooth air coupler. Having done all that, I wish I'd just gotten the Halltech Stinger. What I have isn't bad, but I bet for the $ or close to it I could have had the Stinger.
Old Mar 17, 2005 | 10:16 PM
RatedX's Avatar
RatedX
From: Spring Hill, Florida Life is all about new beginnings;...TRY ONE!
St. Jude Donor '07-'08
Originally Posted by 66427-450
agree 100%.......
SAND????!!!!!
Is this true? ....are oiled filters going to hurt my baby????????
Old Mar 17, 2005 | 10:38 PM
MikeNMaxZO6's Avatar
MikeNMaxZO6
I use the Fram Airhog! Got about 40hp gain!!!
Old Mar 17, 2005 | 10:58 PM
EHS's Avatar
EHS
Donaldson Blackwing.
To Which air filter?
