Help, how to stop hood from banging
Old Mar 17, 2005 | 04:16 PM
ericdwong's Avatar
ericdwong
Default Help, how to stop hood from banging
I've had a really strange sound when I drove over certain bumps and I finally isolated it to my hood. For some reason my driver's side bangs when I go over bumps. I've tried to adjust the rubber stop, as well as to reposition the latch but no luck. My only solution was to wrap the hood striker with electrical tape, It works great but that usually wears out after a few hood closings. Help!
Old Mar 17, 2005 | 04:18 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
I can't understand why it's banging especially if you've done adjusting Something is not right...somewhere.
Old Mar 17, 2005 | 04:30 PM
F1_SS's Avatar
F1_SS
Take it in for warranty, let them solve it.
Old Mar 17, 2005 | 04:35 PM
ericdwong's Avatar
ericdwong
No warranty, car is a 1998, used and with 85K miles on it. Must DIY
Old Mar 17, 2005 | 05:23 PM
Got to be an adjustment in either the rubber tipped adjusters or the latch mechanism. Maybe check the mounting bolts that hold the hood on in the front too - they could be loose. May just have to experiment with it until the rattle goes away. Best of luck.
Old Mar 17, 2005 | 09:47 PM
Wisdom's Avatar
Wisdom
Let the cat out!
Old Mar 17, 2005 | 11:04 PM
EHS's Avatar
EHS
Are you sure the hood is completely down and locked?
Old Mar 18, 2005 | 12:06 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I haven't heard of this one. It does sound like an adjustment though.
Old Mar 18, 2005 | 08:26 AM
Wah's Avatar
Wah
On a previous car I used to own, I opened/closed hood so often that the hinges were worn out and they have a little play. They caused a short, rattling-type noise when going over rough surface. Check to see if your hinges are in the same condition.
To Help, how to stop hood from banging
