is shaking at 150 normal?
Old Mar 17, 2005 | 08:02 PM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default is shaking at 150 normal?
there is some very noticable vibration. the rear-view vibrates bad enough that you can't even see behind you with it. Up to 140 it's fine.
just an alignment issue?
Old Mar 17, 2005 | 08:08 PM
ecook's Avatar
ecook
No vibration here!!
Old Mar 17, 2005 | 08:11 PM
NSTG8R's Avatar
NSTG8R
sounds like a tire and or an alignment issue
Old Mar 17, 2005 | 08:15 PM
98stocker's Avatar
98stocker
My R1 started to shake at 175................
Old Mar 17, 2005 | 08:16 PM
StuzVette's Avatar
StuzVette
Cherish your Hopes...
St. Jude Donor '05-'06-'07
you or the vette?
...StuzVette makes others shake
Old Mar 17, 2005 | 08:18 PM
pinskiC5's Avatar
pinskiC5
Originally Posted by stuart
you or the vette?
Guess I'm not as ballsy as some folks, but the fastest I've had my car up to was 120...and that was just to scare a girl
Old Mar 17, 2005 | 08:22 PM
BeastieBoys21's Avatar
BeastieBoys21
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
I've only had it up to 130 or so.....sounds like it may be the alignment
Old Mar 17, 2005 | 08:40 PM
mcronec5's Avatar
mcronec5
You can have your wheels rebalanced. I hit 150 once. Not really interested in doing it again.
Old Mar 17, 2005 | 08:45 PM
Alignment or balance. I'd check the balance first.
C5inWV's Avatar
C5inWV
I notice alot of vibration on the videotape of my rides over 140, most recently at VIR. I think this is normal turbulence. It may not be as bad if the windows were up, but they are always down at the track.
I think alignment issues are likely to be felt at lower speeds. One wheel out of balance gave me a vibration at 80 mph.
At 140, I am concentrating on everything. In 4th gear, this is just before the shift to 5th. My car feels solid, but there is alot more information to process at that speed. I have not lowered my car. I have a rake of 3/4" from front to back. With less of a rake, the front end seemed to get light at that speed.
Old Mar 17, 2005 | 08:58 PM
NSTG8R's Avatar
NSTG8R
yeh .. now do it with the top removed.
smooth as glass.
Old Mar 17, 2005 | 09:09 PM
BBates's Avatar
BBates
Mine is solid as a rock all the way up to 165!!! However, boy does my passenger window whistle and my knuckles turn white at that speed.
Old Mar 17, 2005 | 09:12 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Cant say as I have never seen 150mph. I get scared
Old Mar 17, 2005 | 09:23 PM
ZO6vettepilot's Avatar
ZO6vettepilot
Most likely tire balance, alignment does not affect or cause vibrations. Are you certain it's really an abnormal vibration eminating from the car/tires etc. and not buffeting at high speeds?
zo6vettepilot
Old Mar 17, 2005 | 09:24 PM
Face's Avatar
Face
160 here and felt like a rock, with the base suspension and upgrades sways.
Old Mar 17, 2005 | 09:27 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
prolly PIO...
Old Mar 17, 2005 | 09:28 PM
mwagne16's Avatar
mwagne16
Close to 160, but I thought the top was going to rip off. Other than that, it was solid as a rock, and I had no problem playing with the radio.
To is shaking at 150 normal?
Old Mar 17, 2005 | 09:33 PM
99C5Vert's Avatar
99C5Vert
St. Jude Donor '03-'11
Once I go past 148, I don't look in the rear view mirror anymore
Old Mar 17, 2005 | 10:06 PM
S76HeliPilot's Avatar
S76HeliPilot
Originally Posted by Grumpy
prolly PIO...
That answer could only come from a helicopter pilot!!
Old Mar 17, 2005 | 10:15 PM
H2oSker's Avatar
H2oSker
Have your tires balanced on a Hunter Roadforce machine. I had a vibration at about 100 and now it is gone.
