Secure Bose Speaker Emblem?
Old Mar 18, 2005 | 12:36 PM
convette01's Avatar
convette01
Default Secure Bose Speaker Emblem?
I have been hearing a terrible vibration from my passenger side front speaker at moderate volume levels and have narrowed it down to the Bose emblem. Has anyone had this problem and found a good way to secure the emblem? The drivers side emblem is not vibrating and is held in the same way.
Old Mar 18, 2005 | 12:40 PM
ericdwong's Avatar
ericdwong
Yes and Yes. Remove the door panel, and then pry up the "pins". Put some glue on the bose emblum, and drop it back down then rebend the pins. I did this but then put POLK AUDIO logo's over the Blose logos!
Old Mar 18, 2005 | 12:44 PM
convette01's Avatar
convette01
Thanks Eric. Do you have a type of glue recommedation?
Old Mar 18, 2005 | 12:57 PM
ALLEGRO's Avatar
ALLEGRO
I suggest RTV
Old Mar 18, 2005 | 01:51 PM
mikejaeggi's Avatar
mikejaeggi
I had the same problem on both front speakers. Took the drivers side apart, removed the grill, placed a small piece of black foam behind the bose emblem, then reattached. no rattle.
Passenger side wasn't as bad so I went the lazy way, stuck a tooth pick behind the Bose emblem then broke it off, leaving just enough prevent it from rattling but not be visible.
Old Mar 18, 2005 | 02:32 PM
convette01's Avatar
convette01
Well I glued it. It's too bad that I have to reassemble to verify that it will work.
Old Mar 18, 2005 | 04:41 PM
D.K.'s Avatar
D.K.
Black silicone glue. Just a dab is all you will need. You can "press form" it around the backside of the emblem with your fingers and wipe the excess away.
Easy
Old Mar 18, 2005 | 05:15 PM
Use just a little epoxy. Just be careful how much you use so it doesn't get on the speaker grill itself.
To Secure Bose Speaker Emblem?
