Help corvette wouldn't start!
Old Mar 21, 2005 | 09:57 AM
ls1vette97's Avatar
ls1vette97
Default Help corvette wouldn't start!
Yesterday i went to start my car which is an MN6 and it wouldnt turn over! Everything had power, and i made sure i pushed the clutch all the way to the floor, NOTHING. I was getting the same effect as trying to start the car without pushing the clutch in though, so finally i decided to mess with the key fob and the alarm system. After locking and unlocking the car several times it finally started...What could be wrong guys? This is the second time in the past week it's happened! PS: Last week i hit the lock button on the key fob while i was inside which turned the alarm on by accident, then started it....Could this have caused the problem? Thanks!
Old Mar 21, 2005 | 10:01 AM
Mark 84ltblu's Avatar
Mark 84ltblu
SE Ohio Event Coordinator
CI-V Car Show Winner
Cruise-In II Veteran
Cruise-In III Veteran
Curise-In V Veteran
Cruise-In VI Veteran
It's quite possible that setting off the alarm has caused this. Are there any codes stored? You might also try cleaning the resistor pellet on the key with some alcohol.
Old Mar 21, 2005 | 10:06 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Check for codes - that is the best way to figure out what is wrong. The symptom sounds like your ignition switch is not sensing the key properly, but codes will tell us for sure.
Old Mar 21, 2005 | 11:36 AM
FixedRoof's Avatar
FixedRoof
My bet is on the key... If you have another ignition key, try that one. The pellet in the key can wear down and cause problems.
Old Mar 21, 2005 | 06:37 PM
cjlaw73's Avatar
cjlaw73
This happened to me. Download the codes.
Old Mar 21, 2005 | 08:41 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
To Help corvette wouldn't start!
