Blackout Taillights
Old Mar 21, 2005 | 04:41 PM
BlackVettesRBest's Avatar
BlackVettesRBest
Default Blackout Taillights
I am thinking of getting a blackout kit for my 2001 black coupe. But I'm not sure if I want to spend $80-$90 on a set. And I don't really want to get the static clings. Is there anyway to paint the taillight covers? And if there is: What kind of paint should I use? Hopefully just something quick, easy, and cheap. Thanks.
Old Mar 22, 2005 | 12:26 AM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
I've painted several set of lights for friends and some folks off this and another vette forum. I use clear paint that I tint with ~18% black. Without a paint gun and compressor, I don't think you can recreate what I've been doing. If you have a paint gun, I'll be happy to talk you through everything involved.
Since the paint quantity is low, I prefer to use House of Kolor products, best paint available IMHO.
Here's a pic of my lights.
Old Mar 22, 2005 | 12:42 AM
C5VetteLS1's Avatar
C5VetteLS1
St. Jude Donor '06-'07-'08-'09
[QUOTE=74-Roadster]I've painted several set of lights for friends and some folks off this and another vette forum. I use clear paint that I tint with ~18% black. Without a paint gun and compressor, I don't think you can recreate what I've been doing. If you have a paint gun, I'll be happy to talk you through everything involved.
Since the paint quantity is low, I prefer to use House of Kolor products, best paint available IMHO.QUOTE]
Way cool, then we could do the side marker light as well since no kits seem to cover them. I paint regularly and have all the required equipment. Did you mask and shoot them in place, or remove them? Also if you can provide a description of the paint you use, or a link? It would be greatly appreciated. Did you scotch-bright your lenses before painting?
Thanks,
Richard
Old Mar 22, 2005 | 12:59 AM
74-Roadster
St. Jude Donor '06
Originally Posted by C5VetteLS1
Way cool, then we could do the side marker light as well since no kits seem to cover them. I paint regularly and have all the required equipment. Did you mask and shoot them in place, or remove them? Also if you can provide a description of the paint you use, or a link? It would be greatly appreciated. Did you scotch-bright your lenses before painting? Thanks, Richard
You have to remove the lights. I have a jig set up to hold the tail lights since they won't sit still by themself.
1. Wetsand off the raised letters with 220 grit.
2. Sand the entire lights with 400 grit, then 600, then 800.
3. Mix up House of Kolor Proflow clear ~ 6 parts clear to 1 part jet black in a clean pint container. Shake the h e l l out of the stuff after mixing and let it sit over night before using. Shake again for 1-2 mintues before spraying.
4. Wash the lights with dawn and wipe off with a clean towel.
5. Tack rag just before painting.
6. Spay 3-4 light to medium coats on the lights allowing 3-4 minutes of flash dry time. Make sure you have enough light and use even consistent strokes or you'll get uneven shading.
7. You can be done or you can let them sit for 24 hours and wetsand with 2000 grit and then spray 3-4 coats again with pure clear. Mine in the picture don't have extra clear over them.
8. Whenever you decide you're done painting, let them dry for 36-48 hours depending on drying temperature. Then wetsand with 1200, 1500 and finally 2000.
9. After the paint is smooth and flat, use a highspeed buffer and I use a mix of 3M polishing compound and 3M swirl remover. I clamp my buffer in a vice so I can hold the lights, not the buffer.
10. After you have a nice gloss, let them sit overnight and then buff again using only swirl remover.
And don't use anything on them but a foam pad on the buffer or a microfiber towel to wipe them off. In the 1st few days, the paint can still be scratched very easy.
Good luck!
Old Mar 22, 2005 | 11:41 AM
C5VetteLS1's Avatar
C5VetteLS1
Awesome Bud, thank you. I had no idea that you could mix clear with black and get a translusent effect. Great information! I'll hope to do mine soon and post some pictures.
Have a good day,
Richard
Old Mar 22, 2005 | 07:11 PM
74-Roadster
St. Jude Donor '06
Have a good day,
Richard
If you have any trouble on the 1st attempt, don't sweat it, sand the paint off and start over. That's how I arrived at the 6:1 ratio.
Also, I found a detail gun or quality airbrush is much easier allowing the painter to apply the paint evenly.
Old Mar 22, 2005 | 09:38 PM
marv1's Avatar
marv1
They look great!!
Old Mar 22, 2005 | 09:50 PM
BlackVettesRBest
I have no clue how to do any of that, nor do I have the equipment. I guess I'll have to skip over the painting and buy a set. Thanks for helping me out with my question though. By the way, your taillights look really sharp.
To Blackout Taillights
