Horn working?
Old Mar 22, 2005 | 03:01 PM
Dave68's Avatar
Dave68
Default Horn working?
Would you do me a favor and check to see if your horn works (not by activating your alarm). The next time you get in your C5, hit the steering wheel to see if you can get the horn to honk.
I've pressed everywhere on my steering wheel and cannot get it to honk, yet the horn does work when the alarm is set. I'm wondering if a switch is not making contact.
Thanks!
Old Mar 22, 2005 | 03:05 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Sounds like the contact switch to me too.
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
mine blows!!! (The devil made me do it)
Old Mar 22, 2005 | 03:06 PM
HummelS's Avatar
HummelS
I honked mine yesterday when I passed my nephew on the street.
, Dave!
Old Mar 22, 2005 | 03:26 PM
Dave68's Avatar
Dave68
, Dave!
Hey Steve, your avatar is misleading! I hope you're experiencing decent weather out there. I can't remember the last time I had to use the horn, so that may be the reason why it isn't working.
....anyone else not use your horn much with this same problem?
Old Mar 22, 2005 | 03:42 PM
v.vet's Z06's Avatar
v.vet's Z06
Mine works....I push the little horn emblem on the steering wheel....works everytime!
Old Mar 22, 2005 | 03:43 PM
jrose7004's Avatar
jrose7004
Mine works!
Old Mar 22, 2005 | 03:50 PM
kg54trains's Avatar
kg54trains
Default Horn operation
I had the opposite reaction. I pressed the horn icon on the airbag and it would not stop. By accident i rubbed the airbag icon and this stopped the horn for 1-2 minutes and would start and not stop. Pulled the fuse to stop. Two Forum members did respond after a thread was placed and the airbag is my problem. Airbag replacement is in my future.
Old Mar 22, 2005 | 10:26 PM
Dave68's Avatar
Dave68
Thanks, everyone. I guess this is not a common problem among C5s. I'll have the dealer fix it the next I taker er in. I'm guessing that inactivity allowed a layer of corrosion to build up and act as an insulator.
Dave
To Horn working?
