Help! Center Tail Light
Old Mar 23, 2005 | 11:01 PM
BJ98's Avatar
BJ98
Default Help! Center Tail Light
The center tail light just went out on my 98 Vette. I just stopped at Auto Zone and thought I could quickly pick up a new light and replace it. Found myself somewhat mystified over how to get to the center tail light. Any suggestions?..........................th ks, BJ98
Old Mar 23, 2005 | 11:04 PM
RockinC5's Avatar
RockinC5
You can get to it by removing one of tail lights.
Old Mar 23, 2005 | 11:08 PM
BJ98's Avatar
BJ98
Thanks for your quick response. I'll try that tomorrow.........BJ98
Old Mar 23, 2005 | 11:11 PM
Green-Hornet's Avatar
Green-Hornet
and the license plate
Old Mar 23, 2005 | 11:16 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
You mean your 3rd brake light? Isn't that LED's?
Old Mar 23, 2005 | 11:30 PM
BJ98's Avatar
BJ98
What is LED's? I'm referring to the center light just above the license plate. I believe you are right though, it only comes on when you press the brake..........thks for input....BJ98
Cajun99's Avatar
Cajun99
Don't bother with AutoZone or any other parts place...they won't have what you need.
The CHMSL is a sealed unit you'll have to get from a dealer or a place that handles GM parts. LEDs are Light Emitting Diodes.
Here's a pic of an "opened" unit from GB's website while a camera was being installed...just so you know what one looks like on the inside.
Old Mar 23, 2005 | 11:43 PM
MyVetteDream
That was my main concern.
Old Mar 24, 2005 | 12:10 AM
BJ98's Avatar
BJ98
Thanks guys! It's off to the dealer tomorrow. Is the license plate or the tail light the best way to get to it, or does the entire light need to be popped out?............BJ98
Old Mar 24, 2005 | 12:15 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
The thing is that led's are a 20 year device. If the led's aren't lighting up it's probably a switch or connector not the light. My .02 Let us know what you find. I'd put voltage to the unit to see if it lights before buying another one. Keep us posted.
Old Mar 24, 2005 | 12:18 AM
Cajun99's Avatar
Cajun99
To me the easiest way to get to the light is to remove the two inner tail lights and reach in and do it by "feel" although some prefer the slightly more involved route of going in through the license plate assembly.
The center light is removed as an entire sealed unit. Unplug it, remove the mounting nuts and pull the whole thing out.
Old Mar 24, 2005 | 07:06 AM
Just remove one of the inboard taillights and you have access.
Old Mar 24, 2005 | 12:38 PM
sempi's Avatar
sempi
If you can wait at all, and you may not want to, the price from your dealer is going to be around $95.00. The price from GMPartsDirect is about $55. The problem is, they do not ship very fast.
Just food for thought.
Replaced mine recently, with a custom, and either inboard tail light is enough, though I ended up taking both inboard tail lights out, since it made it easier to get to the screws on the 3rd Brake light.
Sempi
Old Mar 24, 2005 | 02:09 PM
Tanner's Avatar
Tanner
I agree with the others, LEDs rarely go out. I would look for other problems such as ground, connector or switch issues.
However, I just ran across stop light on e-bay:
http://cgi.ebay.com/ebaymotors/ws/eB...963928315&rd=1
BTW, not affiliated with this sale.
Old Mar 24, 2005 | 02:23 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Check with Ken Fitchner (Forum Sponsor) before you got to your dealer. Ken is an excellent vendor and a good friend of the Forum. He can probably get you a better deal than your vendor. Also, I would ask around about what else might be going wrong with the light. I wasn't aware (any by far I'm not an expert) that you could have this problem with an LED.......just double check. Might save you some Bucks.......
Old Mar 24, 2005 | 05:45 PM
Qcksilverc5's Avatar
Qcksilverc5
Default You guys on this site are AWESOME !!!!!!!
All the info one ever needs is here!!!!
Old Mar 24, 2005 | 09:49 PM
Admiral Fairway's Avatar
Admiral Fairway
Usually on LED's they will not burn out all at the same time( as you can see from the photo above the unit is made up of a lot of small bulbs). If the complete unit is not lighting I would suspect another problem.
To Help! Center Tail Light
Old Mar 25, 2005 | 11:27 AM
diverdan's Avatar
diverdan
Why not pull the unit then hook a multimeter to the plug and have someone press the brakes. You would know if you're getting voltage to the light and rule out other problems first.
Old Mar 25, 2005 | 08:33 PM
BJ98's Avatar
BJ98
Well, what I thought would be a quick trip to Auto Zone is turning into an adventure. Unfortunately I don't get the opportunity to get on the internet as often as I'd like (although I just got high speed internat cable this past weekend). Consequently I went out and got me a replacement light. Nonetheless, I plan to do all the tests and if needed I'll return the light I just purchase. I'll let you know how it turns out....BJ98
Old Mar 25, 2005 | 08:53 PM
MyVetteDream
Look in the Parts section ... maybe some one has one you can use. Good luck. Keep us posted
