Help! Center Tail Light
Old Mar 26, 2005 | 11:36 AM
DeeGee's Avatar
DeeGee
Originally Posted by Stock Man
The thing is that led's are a 20 year device. If the led's aren't lighting up it's probably a switch or connector not the light. My .02 Let us know what you find. I'd put voltage to the unit to see if it lights before buying another one. Keep us posted.
It would be worth checking this out first. Seem to remember when I checked the price that these lights are about $100 each
Old Mar 26, 2005 | 11:52 AM
WilliamCall's Avatar
WilliamCall
The third brake light is indeed an LED unit. It lists for $100. at either Ecklers or Mid America (probably not the best price). Remove either one of the inboard brake lights to gain access to the third brake light. It is attached with two screws from the bottom. There is a two pin electrical plug that plugs into the bottom. I agree with the previous post, LEDs should last for a long time. I would check the electrical connection and the water tightness of the light unit.
Old Apr 2, 2005 | 12:36 PM
BJ98's Avatar
BJ98
Default In Conclusion
I ran a quick test as was suggested and guess what. It was a loose wire. Luckily I did not have to take the light out, I just unplugged and replugged the light. Now I have a $92 replacement. Lesson Learned: If you want good advice, be patient! bj98
Old Apr 2, 2005 | 12:56 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Thanks for posting the result. So many don't. And if you bought it at a dealer won't they take it back? It's Led's.
Old Apr 2, 2005 | 06:18 PM
Cajun99's Avatar
Cajun99
Glad to see you worked it out.
Old Apr 2, 2005 | 06:24 PM
lowdowndirty's Avatar
lowdowndirty
Not if it was special order.
