Yet another oil question
stick with the good stuff, Mobile1, redline, royal purple
Love Syntac 10-30 summer, 5-30 8 months of the Year
Mobil One burns, easy doesn't work for me, Chech the amsoil
Oil tests Syntac rates higher than Mobil -One. I don't go by,that
any way. Castrol is as much as synthetic as Mobil-One is,
Phoneys were trying to sue when they were doing the same thing.
Castrol's a great Oil, U can run the **** out of it,400,000
since 93 1, lt-1 2, ls1 1,-ls-6 .
Never burns, Never a Failure
I use Magnatec 5w30 in my C5, and this is a fully synthetic oil. I can't prove it, but the car seems quicker to me and there is no oil loss/use between 10k oil changes.
I also use the Castrol diesel equivalent in my family car. Three weeks ago we suffered a smashed sump on the autoroute and athough we ran for more than 150kms before the oil warning light came on there was no damage whatsoever to the engine internals.
This said, you absolutely will never have a problem if you keep on using Mobil 1 or any other respected brand of oil that is synthetic and meets a minimum of 5w30. If you live somewhere with extreme temperature ranges then a 0w30 or 0w40 might very well be marginally better for you.
Happy motoring.
Here's Castrol's short briefing on synthetic oils.
http://www.castrol.com/castrol/gener...tentId=6003233
and on the oil I use:
http://www.castrol.com/castrol/produ...tentId=6008780
Last edited by Cochemarman; Mar 25, 2005 at 02:47 AM. Reason: additional castrol link
Here:
"SAE xW-xx is the most recommended grade in today's new cars. Exceeds all car and light truck manufacturer's warranty requirements for the protection of gasoline, diesel and turbocharged engines where API SM, SL, SJ, SH, CF or CD is recommended. Exceeds European ACEA: A1, A5,
B1, B5, Corvette GM 4718M, GM 6094M, Ford WSS M2C929-A and all requirements of ILSAC GF-4 for API Certified Gasoline Engine Oils and meets Energy Conserving Standards.
Here's the link:
http://www.castrol.com/liveassets/bp...syntec_usa.pdf
If you read the service manual, an oil meeting ACEA A3 standards can be used in place of GM 4718M. By the way, Mobil-1 doesn't meet ACEA A3 and the German made Castrol 0W-30 does.
Good tip!
Good tip!
The gentleman who postred seemed to imply that Mobil-1 doesn't meet the specs required for use in the Corvette -- which it does.
That is all. Over and out.
End of transmission.
Stick with the good stuff, you've got an expensive machine don't skimp on the small stuff
P.S. I just like to post so I can attach my Sig, I'll grow out of it eventually!
