Z51 or Not ?
Old Mar 25, 2005 | 07:47 AM
CAJUN ZZ4
Guest
Posts: n/a
Default Z51 or Not ?
Searchimg for my C5 I'm educating myself on what options to get or stay away from. My C4 has the Z51 option ..lost too many teeth fillings, Anyone have the Z51 suspension out there and are you glad/sorry,you have it? I'm not going to race the car per. say.
I Appreciate your input
Old Mar 25, 2005 | 07:56 AM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I have it and love it. It's not harsh at all. We've taken trips of many hundreds of miles and loved it. More comfortable than our old Caddy boat.
steve8's Avatar
steve8
I have the adjustable suspension on my 04 vert. You will notice a huge difference in the two cars. Set mine on touring and the ride is smooth, and a noticable difference on sport. I'm not sure what year you are considering, but I love my 04.
Good luck.
Old Mar 25, 2005 | 08:04 AM
denali's Avatar
denali
St. Jude Contributor
I have the Z-51 option on my 03. I don't race and really don't drive it that much. With that being said, I don't find the ride harsh. My 01 didn't have it but after driving a friends with the Z-51 persuaded me to order it on my present car. No regrets here.
Old Mar 25, 2005 | 08:19 AM
Richin Chicago's Avatar
Richin Chicago
Don't even think about a C5 without Z51. It's a great suspension and really causes the Vette to come into it's own. If you want the best of both worlds get the Z51 with some good aftermarket tires.
Old Mar 25, 2005 | 08:34 AM
Lancer033's Avatar
Lancer033
Old Mar 25, 2005 | 09:53 AM
ArmyVette's Avatar
ArmyVette
Traded in my 04 coupe with base suspension and A4 for a 2002 vert with MN6 and Z51. Carried my Michelin Pilot Sport A/S runflats over to the vert as well.
The Z51 with the Michelins are a great combination. I like the "positive contact with the road" feel that I get with the Z51 that I didn't have with the base suspension. And good rubber makes a heck of a difference as well.
Old Mar 25, 2005 | 09:56 AM
MHVette's Avatar
MHVette
I'm so glad I held out for the right C5 w/ Z51!
Old Mar 25, 2005 | 10:19 AM
byte_me's Avatar
byte_me
I love my 97 Z51 coupe...I had an 84 Z51 coupe and that was the harshest ride I have ever felt! But It was fun...the C5 Z51 is stiff yet not harsh to normal driving conditions...it corners great and I can drive hundreds of miles and not feel like I did when I got out of the 84...like I got gut kicked!
I would highly recommend it! you will miss out if you go without!
Old Mar 25, 2005 | 11:48 AM
Dave68's Avatar
Dave68
Car & Driver wrote that the Z51 option is the best option on a C5, bar none - and I totally agree. However, to make the best of this suspension option, combine with non-runflat tires for an incredibly smooth, yet firm ride. I have Goodyear GSD3 tires and couldn't be happier with this combo.
Old Mar 25, 2005 | 12:23 PM
Ron C!'s Avatar
Ron C!
I have the Z51 with Koni's. Great ride, better handling. Wouldn't buy a car without it.
Old Mar 25, 2005 | 01:16 PM
The Z51 suspension is not the same as when it first came out on the '84's - then it would rattle you to death. This suspension on the C5 is less harsh and makes a difference in the handling. I'd recommend it if you find a car with it and all the other options you want.
Old Mar 25, 2005 | 01:23 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Not harsh for everyday use. I love the Z51 on my 02. It was the best bargain on the entire option sheet.
Old Mar 25, 2005 | 05:15 PM
6 speed Sid's Avatar
6 speed Sid
I have the Z51 option and in my opinion it's the only way to go.
Old Mar 25, 2005 | 05:18 PM
speedfreek155's Avatar
speedfreek155
My '99 FRC has the Z51 option , and I wouldn't have any other way .
Old Mar 25, 2005 | 05:22 PM
sailohio's Avatar
sailohio
Last week I drove 1560 miles in two and 1/2 days with my 02 Z-51 M6 Coupe. Never once did I get uncomfortable with the ride or the seats. Many cars I've had in the past would have given me saddle sores. Not my baby.
Old Mar 25, 2005 | 06:10 PM
KHM_70's Avatar
KHM_70
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Rides like a Caddy, handles like a Vette.
To Z51 or Not ?
Old Mar 25, 2005 | 07:06 PM
98stocker's Avatar
98stocker
Other then bigger swaybars whats the diff?.....Noob to z51
Old Mar 25, 2005 | 07:26 PM
Tino's Avatar
Tino
Jeff,
What was it like going from an A4 to the MN6 ?
Tino
Old Mar 25, 2005 | 07:47 PM
C5COM67's Avatar
C5COM67
The change from base to Z51 that effects the ride is the front and rear springs. Sway bars won't make the ride more harsh, they reduce the lateral roll induced during a turn and work with the springs in that aspect. The next higher level is the Z06 package which uses the same front spring, rear spring about 10% stiffer, and the sways have a larger diameter than the Z51. There are a few levels above that in the aftermarket world also, all the way up to the T-1 set-up used on the C5-R racer.
Something else....base/Z51/Z06 suspension parts are interchangable, meaning you can mix/match between the different levels if you chose. This allows for upgrading a little at a time to the level you want to achieve.
