First corvette , have some ?'s
Old Mar 26, 2005 | 05:44 PM
jules9's Avatar
jules9
Default First corvette , have some ?'s
Earlier I was asking about tires and exhaust.Just wanted to know will getting new tires help that much . Took the wife to our house in o.c,nj and the ride was really brutal on some roads.Will getting rid of the runflats be a major improvment or will I need different shocks to smooth the ride a little.First VETTE so I was just wondering if the rough ride was somthing i have to get used to.Not complaining, I do love the car.
Old Mar 26, 2005 | 05:50 PM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
It depends.
I didn't catch your first post so I don't know how your car is equipped, but if you have the Z51 handling suspension, it is...firm. It took some getting used to for me as well, but now I don't have a problem with it.
Yes, non-runflat tires will make a significant difference in the ride. The ride with runflats is pretty stiff due to the extremely stiff sidewalls of a runflat tire.
You can also put Michlen Pilot Sports and Kumho Estacia run flats on and realize an improvement in ride but not to the extent of the non-runflats.
BTW, welcome to the forum. Got pix of your new baby?
Don't forget to wave!
Old Mar 26, 2005 | 05:51 PM
lynxshooter's Avatar
lynxshooter
I would be careful with replacing the shocks. I have a friend that replaced his shocks and his ride was MUCH worse. If you bought used, maybe check to see if your shocks are original.
hope this helps.
Old Mar 26, 2005 | 05:54 PM
jules9's Avatar
jules9
Thanks.No pictures yet but it is a 99 blk with vigilante torque conv. and 383's.Everything else is stock.Runs super strong.
Old Mar 26, 2005 | 05:55 PM
jules9's Avatar
jules9
It is all original only 26,000 on it.
Old Mar 26, 2005 | 06:00 PM
Kris072's Avatar
Kris072
Make sure they didnt leave the shock stuffers in. The ride is horrible and a lot of dealers forgot to take them out.
Old Mar 26, 2005 | 06:04 PM
jules9's Avatar
jules9
What are shock stuffers?
Old Mar 26, 2005 | 06:06 PM
HummelS's Avatar
HummelS
Shock stuffers only apply to 2003+ model year with F55 adj. suspension.
Old Mar 26, 2005 | 06:09 PM
Kris072's Avatar
Kris072
The rear shocks can be seen by crawling under the rear of car and reaching up the shock rod. Push up the black rubber boot and see if a yellow plastic strap is hanging down. the front is a bit harder to see w/o jacking up the car. You might try turning the wheels hard one way, and look from the rear of tire. If they are there, just push up the black boot, and push the stuffer out from one side. the stuffer has a slot on one side to push off the rod.
Let me see if I can find a picture for you.
Old Mar 26, 2005 | 06:12 PM
Kris072's Avatar
Kris072
All 2003 Corvettes with magnetic suspension, which includes all Anniversary Editions, leave the factory with "shock stuffers" placed on each shock absorber to prevent the suspension from bottoming-out during transport. This is required as there is essentially no shock absorber action when current is not applied to the shocks. During the new vehicle preparation, the dealership is required to remove these shock stuffers. Since this is a new procedure for the dealer and it's not required on any other Chevrolet vehicle, many technicians are not aware of this procedure and cars have been delivered to customers with the shock stuffers still in place. Failure to remove these shock stuffers will result in poor ride quality.
The shock stuffers are placed by the factory under the dust cover of each of the car's four shocks. Removal of these stuffers requires jacking the car so the suspension can hang (or on a lift), pushing up the dust covers and removal of the stuffers. A yellow tag may be noticed protruding from the shock dust covers if they are still in place.
Old Mar 26, 2005 | 06:14 PM
jules9's Avatar
jules9
you know your stuff.Thanks.Hopefully the new tires will help the ride.
Old Mar 26, 2005 | 08:24 PM
Qcksilverc5's Avatar
Qcksilverc5
Default these guys don't mess around baby!!!
Old Mar 26, 2005 | 08:37 PM
Big Jay E's Avatar
Big Jay E
I put up with the lousy ride and noise until my GY runflats needed to be replaced. I went with the Michlien Pilot Sport runflats, as as much as I don't want to support the French, I can't quit talking about these tires. You will think it is an entirely different car.
Jay
Old Mar 27, 2005 | 12:03 AM
If you have the stock Goodyears, then the ride rough naturally. Putting on a set of non-runflats will help alot - at least it did on my car when I switched to the Goodyear F1 Supercars. In addition to the other runflats mentioned above, the Firestone Firehawks give a better ride (IMO) than the stock Goodyear EMTs.
To First corvette , have some ?'s
