Front Fascia Oddity
Old Mar 27, 2005 | 07:21 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
That's just not right.......I've never seen anything like it before. Do you have any more details? Did you buy the car this way?
Paul
Old Mar 27, 2005 | 08:49 AM
Dark-Knight's Avatar
Dark-Knight
Did you buy it from a dealer that way?
Old Mar 27, 2005 | 08:58 AM
Z0SLIK's Avatar
Z0SLIK
Originally Posted by Cajun99
That's not right.
Old Mar 27, 2005 | 09:10 AM
indy300's Avatar
indy300
Alright, I just bought it from a small dealer two weeks ago. I knew something wasn't right, but wasn' too concerned. I'll take more pictures today and post them.
Old Mar 27, 2005 | 12:57 PM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Old Mar 27, 2005 | 12:58 PM
indy300's Avatar
indy300
Here is a link to several photos of the fascia problem. You can see both sides are very similar. I think I may take the headlight apart and hopefully I can see underneath this area.
http://community.webshots.com/script...umID=306236453
Old Mar 27, 2005 | 01:06 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Here what I got when I clicked your link:
An error has occurred.
You do not appear to be the owner of this album.
Make sure you are logged in.
Please push the Back button on your browser to correct this problem.
Thank you.
You must post the actual URL of the photograph. Good luck.
Old Mar 27, 2005 | 01:43 PM
indy300's Avatar
indy300
I'll try this:
Last edited by indy300; Mar 27, 2005 at 08:27 PM. Reason: hopefully fixing the photo problems again!
Old Mar 27, 2005 | 02:44 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
I think I would be taking the front facia right off. And see just what exactly is going on. I'll bet it's probably a new front facia after an accident. And whoever put it on didn't know what they were doing. Keep trying the pics so we can see whats going on under there.
Old Mar 27, 2005 | 02:55 PM
Dr. Dan's Avatar
Dr. Dan
Here's a thought...If both Rt and Left sides are similar, think about HEAT. What kind of headlights are (were) you using? The position suggests excessive heat at the lowbeam area.
Old Mar 27, 2005 | 03:03 PM
TexasMadMan's Avatar
TexasMadMan
Yes, I also mentioned heat a few posts back , but I think a past accident is the true cause.
Old Mar 27, 2005 | 03:13 PM
indy300's Avatar
indy300
I suspect the car has stock lights. I think the fascia has been off and during installation, a fastener was overtightened. I've been looking through the service manual about fastening the fascia. It appears there is a fastener in that area with very specifice torque requirements.
And whats up with my red X photos? I previewed the post and everything looked fine...
Old Mar 27, 2005 | 04:23 PM
  #33
Benpup's Avatar
Benpup
Cruise-In VI Veteran
As Willie Nelson says,
"Not sposed to be that way!"
Old Mar 27, 2005 | 06:03 PM
  #34
indy300's Avatar
indy300
Ok this is what I found out. I took the headlight cover off and looked down inside the fascia and saw a big spring pulling the bent area down. WFT. If the pictures show up you can see how much tension was in the spring. I then loosened the fascia connection to the body panel in the bent area to try and relieve the stress on the fascia. It moved a little. With any luck at all, the fascia will move back to its original position over time. I doubt it, but I'm not going to let this thing ruin the car for me!
Old Mar 27, 2005 | 06:07 PM
  #35
indy300's Avatar
indy300
I have no idea why I can't post pictures!!AAAAAHHHHHHHH
They look fine when I preview the post. If you want to see the pictures I'v mention...go to www.webshot.com and search my name "indy300"
Old Mar 27, 2005 | 06:12 PM
  #36
TexasMadMan
I just did a search on the site listed above and over 39,000 photos came up. Don't believe I have time to look at all of them.
Old Mar 27, 2005 | 06:23 PM
  #37
indy300's Avatar
indy300
Go to the "community" photos and and then type "indy300" in the "find a member" line near the bottom. Sorry for the hassle. I don't know why only 1 of the 4 photos showed up in my previous post.
To Front Fascia Oddity
Old Mar 27, 2005 | 06:26 PM
  #38
Stock Man's Avatar
Stock Man
I found your pictures, in Community and search for members. Man that's weird have springs like that there. I wonder if someone re-installing the facia put them there to hold it in place, till it was secured properly. Then never went back to take them out. They are the size of drum brake springs. Good thing you got them out of there. It may return to normal once things heat up in the summer. You could probably pull up on the corners every now and then. Over a period of time it should probably come back. Maybe heat the area with a heat gun and give it a try. Just don't burn the paint. Keep us posted. And good luck with it. And your right don't let it ruin your experience with the car. This is fixable.
Old Mar 27, 2005 | 07:16 PM
  #39
neural's Avatar
neural
If the car had been bumped at one time from the front, wouldn't it also cause some missalignment along the hood as well?
Is it possible that this is a slightly incorrect after market part?
With other cars, I think it's possible that the differences between a couple years might cause this sort of result. Are the C5 Corvettes all exactly identical in body style?
Old Mar 27, 2005 | 07:19 PM
  #40
charliesc5's Avatar
charliesc5
ouch....looks like it hurts
