[Z06] vararam owners
Old Mar 27, 2005 | 12:23 PM
xxsvtcobrakidxx's Avatar
xxsvtcobrakidxx
Default vararam owners
about to order the vararam system from lapd what is there special filter like??? what filters are you guys using with this system?? ive finally decided between this and the vortex and i just wanna make sure i get the right filter thanks
Old Mar 27, 2005 | 01:26 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
The new Vararam 2b has a better filter than the older style that most don't like. Some guys like to replace even the new style with after market. I think the new stock 2b out flows any of the others and I am running it and happy with quality/performance.
Old Mar 27, 2005 | 01:39 PM
forloop's Avatar
forloop
I got a Vararam from LAPD, great service fast response. The filter that LAPD sells is a ok filter. I am planning on some PJ1 to help. I also ordered a K& N filter. That is an extra $44. LAPD can get them for you. They fit pretty well, but need some molding to help them seal.
Take Care,
Old Mar 27, 2005 | 01:55 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I just installed the VB2 with the filter provided. I will see how it works out.
BC
Old Mar 27, 2005 | 06:12 PM
Vettez16's Avatar
Vettez16
VR-B2 comes with a multilayer foam filter. It is designed more for the drag strip than daily driving. It works well under normal driving; i.e. non-dusty areas. The response is immediate and becomes more crisp at higher speeds. If you are using the car as a daily and in all conditions use the K & N filter - about $50.
Also if you are installing the system yourself, remove the shroud that the stock air box was mounted on for a much easier install. Becareful of the surroundind sensors and connections. Good LucK!
Old Mar 27, 2005 | 06:55 PM
pb24dagrk's Avatar
pb24dagrk
my car is a daily driver and i have the vararam, and use the filter that came with it
since i'm in so. cal., dust or extreme weather isn't an issue at all
i checked the air filter after 5,000 miles and it was clean
To vararam owners
