what does competetive driving do, i didnt realize 6-speeds had it, the other day i held the traction control button down and it come up on the screen. right after that my car started to mess up, the sepentine belt started ripping, or i started to notice it making a noise under hood right after i turn it on. I get home and i see my car is leaking something, looked like oil but it was cold and smelled like gas, the belt was ripped down to about nothing, all this happened right after i hit the competetive driving button, could that of caused this.
NO
Competetive Driving Mode = No traction Control BUT Active Handling still on. That also means be cool as you can get in trouble if you aren't careful
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
No, CM did not cause your problems. CM switches off Traction Control but keeps Active Handling enabled. It allows you to drift the front, rear or all 4 tyres during aggressive driving. It does not affect your engine.
It's also great for smokey burnouts and for laying down 30 feet of rubber too
EG
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
Originally Posted by BWP 5P
NO
EG
I have not tried but wondering in a smoky burnout when the rear end drifts right, will active handling correct (in comp mode)? If yes how will it correct by reducing tire spin (ie rear braking)?
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
