Can someone help (service report explain)
I am looking to buy a C5, found a few, got some information back from one of the sellers, service reports, clean title , etc.. I was wondering if any of ya'll could look at it and give your opinions? It's a .doc file, so if you wouldn't mind helping me I could send it via e-mail to ya. I just wanted to make sure that it's not a lemon or gonna crap out on me based on the past service reports (might not even be bad, could be just maintenance) but just want to make sure
TIA
Kasp!
or send it to my Yahoo account (same userid)
Labor Operation Odometer Reading
N1730 - BLOCK ASSEMBLY, WIRING HARNESS JUNCTION - ENGINE - REPLACE 32331 miles
B2368 - HANDLE, HATCH ROOF - REAR - REPLACE 32331 miles
Z7904 - 4-DAY COURTESY TRANSPORTATION 32331 miles
N4800 - MODULE, COMPUTER (CONTROL) BODY - REPLACE 22576 miles
D1322 - MOTOR AND/OR FAN, BLOWER - A/C - R&R OR REPLACE 22576 miles
T2020 - TOWING 22213 miles
V0743 - ECL RELAY HARNESS REPLACE 22213 miles
Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 22213 miles
R4480 - RECEIVER, REMOTE DOOR/REAR COMPARTMENT LOCK - REPLACE 22213 miles
E7660 - COLUMN ASSEMBLY, STEERING - R&R 22034 miles
E7200 - CYLINDER, IGNITION LOCK - R&R OR REPLACE 22034 miles
V0505 - INSPECT LAP BELT RETRACTORS,INSTALL WEBBING GUIDES 22034 miles
V0743 - ECL RELAY HARNESS REPLACE 22034 miles
Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 22034 miles
J0667 - BELT, PRIMARY ACCESSORY DRIVE - REPLACE 21219 miles
C1012 - WEATHERSTRIP - ROOF - FRONT - ALIGN OR REPLACE 21180 miles
M0017 - LUBE, OIL AND FILTER 21180 miles
B7240 - BEZEL - HEADLAMP - RIGHT - REPLACE 17511 miles
M0017 - LUBE, OIL AND FILTER 17513 miles
H0127 - ROTOR ASSEMBLY - FRONT - BOTH - R&R OR REPLACE 17513 miles
H0137 - ROTOR ASSEMBLY - REAR - BOTH - R&R OR REPLACE 17513 miles
N3620 - W/S WIPER ARM RPL 17513 miles
M0017 - LUBE, OIL AND FILTER 13600 miles
M0017 - LUBE, OIL AND FILTER 10499 miles
B2510 - LATCH/LOCATOR ASSEMBLY, ROOF PANEL REAR - RIGHT - R&R OR R 10499 miles
C2420 - PANEL, INSTRUMENT PANEL CLOSEOUT (INSULATOR) - RIGHT - R&R 10499 miles
M0017 - LUBE, OIL AND FILTER 8014 miles
H0137 - ROTOR ASSEMBLY - REAR - BOTH - R&R OR REPLACE 6784 miles
M0017 - LUBE, OIL AND FILTER 5600 miles
N9995 - CUSTOMER CONCERN NOT DUPLICATED 4305 miles
M0017 - LUBE, OIL AND FILTER 3825 miles
Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
-- Kasp
I do NOT know enough about this car but if I were thinking of buying it and THEN read this report, I'd pass this one up and continune looking.
That is just MY opinion, I am NOT an expert by any means.
The previous owner seems to have cared for the car pretty well, just the cars seems to have had too many problems for me.
