NEED HELP...Quickly...Plz do reply....
Old Mar 30, 2005 | 06:28 AM
Vette_Fan's Avatar
Vette_Fan
Default NEED HELP...Quickly...Plz do reply....
hey guy, I hve 2 questions. 1. I bought the car about 2 months ago. I dont drive it much yet...just went out with it a few time. 2 days ago, noticed battery went down, so gave it a jump 2 days ago, drove around the house. TODAY the battery was down...again. Jumped and then drove off and on all day...worked ok. My question, whats up? I also got the DIC message saying, Pull the key, wait 10 seconds. The battery has gone down 2 times in a week.
My 2nd question is that it has the 12 CD changer. Worked ok the first few times, when loaded with CDs. TODAY, I was getting Err message on the stereo display. It won't work, why? Same CDs would play fine if I insert them one by one in the main CD player. But when I stick them in the 12 CD changer in the trunk, it won't work. Any ideas? Is that related to the battery issue? Either way, HOW can I fix it ? Thanks
99 coupe, a4, 2.73, all stock - for now!
Old Mar 30, 2005 | 06:43 AM
JTE's Avatar
JTE
CI 4-7, 9 & 10 Veteran
It is very likely the battery. When the car is running, check the battery voltage on the DIC. If it shows around 13.8 volts, that is a good indication that the alternator is probably OK and the system is charging.
Old Mar 30, 2005 | 06:49 AM
jman1's Avatar
jman1
sounds like the battery... the car will freak when theres a bad battery....... jump it check the volts on the dic ... if its about 13.8 it prolly the battery.. go get an optima red top from sears
Old Mar 30, 2005 | 07:08 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
These things flip out when the battery starts to go
Old Mar 30, 2005 | 07:16 AM
andy60's Avatar
andy60
The CD's may be upside down? I did the the first time I loaded the my CD's
Old Mar 30, 2005 | 08:24 AM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
If you still have the original side post Delco in there, you'd better read this
Old Mar 30, 2005 | 08:41 AM
bogiemanjoe's Avatar
bogiemanjoe
I know that my C5 went apes%$t when my battery died and was jumped. I bought a new Optima Red Top at Sears and have never had a problem since (knock on wood). It sounds like your Battery is the problem. Remember the C5 will shut down some systems if the battery is going bad.
Old Mar 30, 2005 | 08:56 AM
DeeGee's Avatar
DeeGee
That would be my first thought.
When my Delco died it was totally undramatic. Everything died instantly. that said, loads of horror stories on the Forum of wierd indications when the battery goes.
I got a Red Top
Old Mar 30, 2005 | 09:07 AM
Vettlldo's Avatar
Vettlldo
I agree...it's not logical but you need to load the CD's upside down in the CD carosaul.
Old Mar 30, 2005 | 09:47 AM
LuS1fer's Avatar
LuS1fer
Change the battery as you get loads of false messages when it dies, none of which are true. however, the Pull key thing can be the onset of the column lock issue for which a bypass may be required. Just change the battery first.
Old Mar 30, 2005 | 10:28 AM
sprinter's Avatar
sprinter
Batery may not be gone... it takes more than just driving around the block to charge it after a long stint in the garage. Mine was dead as dead... and after a 1hr drive on the highway, it seems to be back to normal.
CD is upside down... did this in my Camaro.
Old Mar 30, 2005 | 02:05 PM
Vette_Fan's Avatar
Vette_Fan
Thanks guys... OK as for the battery issue, you all seem to love Red top. Great! But I've a question, a battery is a battery, isn't it? I've a awesome Exide battery that I just bought 2 yrs ago for the 300ZX. It wasn't the factory recommended battery (550 CCA). Its the 740 cold cranking Amps, nice, strong battery. I've always got the more powerful batteries in my cars. So, can I just stick that battery in the C5, if it fits? I'm sure it'll work....or do really have to buy a new battery?
As for the CD issues, I'm sticking all those lil trays into that plastic magazine, exactly as I did before...and as the arrows are pointed. I pull the magazine out, pull the tray out, and lay the CD in it...Label facing up, and the shiny part down. Put everything back as normal, and close the CD box. I'm not sure if this is just due to the battery issue. I drove the car off and on pretty much all day yesterday, and it seems to be working ok now. But I'm still confused with the CD issue.. Thank...appreciate your replies... Plz keep em coming... P.S: There are original CDs, not copies.
Old Mar 30, 2005 | 02:46 PM
Benchpress's Avatar
Benchpress
Did you copy the cd's? My changer will not play copied cd's! As far as Batteries, They are not all the same. The optima is a dry cell battery and the battery in your C5 sits right above two computers. Wet cell batteries tend to leak, and have caused problems with these computers. something to think about when you have to replace the battery.
Old Mar 30, 2005 | 05:35 PM
speedfreek155's Avatar
speedfreek155
Battery , like everyone said , and dont discount ground probs . Look for thread posted by Bill Curlee on ground problems .
Old Mar 30, 2005 | 06:25 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
My Delco died without warning and after I got it jumped, went and got my Red Top. Trouble-free ever since.
Old Mar 30, 2005 | 08:00 PM
Vette_Fan's Avatar
Vette_Fan
Default Love this forum ... and everyone...
Hey....Thanks for all the replies guys... I did put the CD upside-down, and it worked. Its really amazing, though not logical at all...but it works if you put the CD in the magazine up side down.
I turned On the car, and it started today. Since I did a lot of driving yesterday, I feel its prolly well charged. I think I should start the car everyday for a few minutes, even if I don't drive it much. Though my other cars will start easily, even if I trun em On after a month. But I guess, Vette needs daily attention....
Anyways, thanks for all the help... Just wanted to say, this forum and guys here ROCK...
Old Mar 30, 2005 | 08:53 PM
JH's Avatar
JH
Insert your car's ignition key, turn to ON but don't start. The readout will tell you the volts your battery is holding. If less than 10.5 or 11, I'd be concerned about the battery. You already have others' advice about the readout showing the charge coming out of the alternator when the engine is running.
To NEED HELP...Quickly...Plz do reply....
Old Mar 30, 2005 | 10:26 PM
RCK1999's Avatar
RCK1999
CD - Labels down - shiny side up (while holding CD carrier with #1 slot on bottom) -
Old Apr 1, 2005 | 03:43 AM
Vette_Fan's Avatar
Vette_Fan
Exactly. It worked. I read the book too later on, and found the same thing. Though its not Logical at all, why would you put a CD upside down... But hey, if that works... fine with me
About the battery issue - I twisted the key to start, without starting the engine. It shows about 12-12.2..or so Volts. So I guess the battery isn't so bad yet. It just needs to get driven a lil everyday. Fine with me..
Old Apr 1, 2005 | 06:18 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
No, a battery isn't just a battery.
Optima batteries, and another brand that I can't remember, are filled with gel rather than water. For that reason they won't leak ever and they won't drip battery acid down on that very expensive computer sitting below them.
There have been some reports recently about defective Optimas, but it seemed like a little spurt of bad batteries and I haven't heard anything else negative about them since.
