led tail lights---- advice!!?
Old Mar 30, 2005 | 07:26 PM
bvetted's Avatar
bvetted
Default led tail lights---- advice!!?
I just installed 4 led tails lights in my 2000 vette and all works fine--- 4-ways -- tail --- stop--- the turn signals work as well, but seem to flash "double time" -- is this normal for leds??? i got them from autolumination.com and followed all instructions. i did install 4- 6ohm equalizers in each light as well. nice looking , but just wondering about the f-a-s-t turn signals. thanks in advance.
Old Mar 30, 2005 | 10:46 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Yeah. It's normal. The low resistence from the LED's causes it.
I'm wondering if the load equalizer isn't enough. Did you address this with Chris from autolumination?
I hope we can get this resolved soon. I've been looking how to do it, and the only thing I can think is get a stronger resistor in there.
If you get any info, please keep us posted.
Dave Q.
Old Mar 30, 2005 | 10:49 PM
Vettlldo's Avatar
Vettlldo
Be sure to email Chris Bacon about your troubles. He was just asking me today how I set mine up. Since I have European taillights, I don't have these same problems (2 different circuits).
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
How do you have the load equilizers hooked up?
I found that I had to have the outside lights ground and outside leed and the inside bulbs ground to inside leed.
Old Mar 30, 2005 | 10:51 PM
MyVetteDream
Same here. But, I'd like to eventually get amber LED's for my signals.
Still need to figure that solution for everyone else as well ...
Old Mar 30, 2005 | 11:31 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Be interested to know which version you used, I tried the 24 or 25 led version and they don't seem as bright as stock.
On the flasher problem - I just wired the stock bulb (painted black)in parallel with the LED bulb to get the right load and it works fine.
Old Mar 30, 2005 | 11:36 PM
JTS97Z28's Avatar
JTS97Z28
Ben Dover,
thats a really clever idea. It would not only make the car think everything is perfect, but would save money in that you will not need to buy 4 load equalizers or resistors which doesnt seem to be working anyway. Im assuming you had to attach a bulb for each taillamp just like normal?
Old Mar 31, 2005 | 06:51 AM
bvetted's Avatar
bvetted
thanks for you help!!! i have been talking w/ Chris and he offered some advice. i did find that the clips supplied with the lights didn't work and they were part of the problem. i put a wire nut on each connection witht he equalizers and that helps. now i have the correct turn signal speed, but when i step on the brake or turn on the driving lights w/ the turn signal on they (turn signal") move into "double time" again. i will keep you posted. i do like the led look, but not the hassel that goes w/ them. i would recommend that wire nuts be applied to each line and the clips take a ride on the garbage truck. thx
Old Mar 31, 2005 | 07:52 AM
ben dover's Avatar
ben dover
Originally Posted by JTS97Z28
Ben Dover,
Fraid so, but you can bend the bulb leads and solder a short wire to them and connect with t-connectors.
Old Mar 31, 2005 | 08:49 AM
bvetted's Avatar
bvetted
Are you guys saying to just wire the original bulb back into the wiring system and put the led lites in the socket-- remove the equalizers-- and it will work????? not too swift when it comes to this - so bear with me. would it be that easy??? thx oh, i used the 25 leds.
To led tail lights---- advice!!?
