Throttle body coolant bypass question
Old Mar 30, 2005 | 11:10 PM
ls1vette97's Avatar
ls1vette97
Default Throttle body coolant bypass question
I have heard you can pick up a few extra ponies bypassing the coolant around the throttle body. Is there a way to do this without buying the kit? The kit just looks like something you could find at any hardware store! Anyone have any info on this? Thanks!!
Old Mar 30, 2005 | 11:19 PM
ivandrea's Avatar
ivandrea
Mines in the garage, but its a Aluminum tube with serrated edge at both ends for hose engagement. Its not worth $19. You can find it on ebay for about $5. Just remove your hose, measure the ID of your hose. The tube should be about 2-3" and slightly larger OD then the hose ID. Get the thinnest wall tubing availble.
Old Mar 30, 2005 | 11:29 PM
lvvette777's Avatar
lvvette777
The air is in the throttle body for a split second, not nearly long enough to get heated up by the throttle body. Just a thought.
Old Mar 31, 2005 | 01:35 AM
Red Rag Top's Avatar
Red Rag Top
Old Mar 31, 2005 | 06:24 AM
WKMCD's Avatar
WKMCD
Only works with the Performance Hood Seal.
Old Mar 31, 2005 | 06:55 AM
Dark-Knight's Avatar
Dark-Knight
Save your money, it's a worthless mod.
Old Mar 31, 2005 | 06:56 AM
The general concensus is that the throttle body bypass really doesn't do much good. IMO, money would be better spent elsewhere.
Old Mar 31, 2005 | 07:15 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
It's a waste of time and money so I did it anyway
EG
Old Mar 31, 2005 | 09:15 AM
JTE's Avatar
JTE
CI 4-7, 9 & 10 Veteran
Old Mar 31, 2005 | 09:18 AM
z06cab's Avatar
z06cab
I dyno'd it and found +11hp if you use the Type R decal in combination.
that mod is useless...save your $2...
Old Mar 31, 2005 | 09:21 AM
C5 4 ME's Avatar
C5 4 ME
Old Mar 31, 2005 | 09:22 AM
JohnTheStigGalt's Avatar
JohnTheStigGalt
EG
Old Mar 31, 2005 | 09:42 AM
BlackVettesRBest's Avatar
BlackVettesRBest
EG
Old Mar 31, 2005 | 09:58 AM
LuS1fer's Avatar
LuS1fer
After exhaustive research, I concluded it coukldn't possibly have any benefit whatsoever and to prove it, I bought it, fitted it and I was right. I could have shoved it up my a** and had the same power gain.
Old Mar 31, 2005 | 10:29 AM
lvvette777's Avatar
lvvette777
ROFLMAO!!!!!!!!!
Old Mar 31, 2005 | 10:43 AM
binkysgarage's Avatar
binkysgarage
Another useless mod that I got sucked into, probably not the last.
Old Mar 31, 2005 | 11:48 AM
Joe Diver's Avatar
Joe Diver
CF Enhanced Member
Cruise-In VI Veteran
St. Jude Donor '06
The only gains from this mod are $$$ in the pockets of those that sell it.
Old Mar 31, 2005 | 12:33 PM
vettenuts's Avatar
vettenuts
The biggest advantage of this mod is the ability of taking the throttle body on and off without the mess. The fluid looks like it only passes through small section of the throttle body on the lower edge. I am thinking about it only because my Shaner is coming in soon and I have to take things apart anyhow.
To Throttle body coolant bypass question
