Tpis Headers, What X-pipe Can I Use?
Old Mar 31, 2005 | 02:36 AM
1-BAD-C5's Avatar
1-BAD-C5
Default Tpis Headers, What X-pipe Can I Use?
Title says it all basically im sort for cash and im just going to go ahead and get the tpis headers, i do not want to reuse my stock h pipe like the headers recommend, i want to use a 3" x-pipe. if anyone can help me with what x-pipe works for these headers please let me know.
thanks
Old Mar 31, 2005 | 07:02 AM
Can't say for sure, but I would think that any X-pipe would work. Someone chime in if I am wrong here. While I do not have the LT headers on my car, I have a Bassani X-pipe and it works just fine.
Old Mar 31, 2005 | 08:29 AM
AU N EGL's Avatar
AU N EGL
I have TPIS long tubes. I use the Random Tech High flow cats and X pipe. GHL Exhuast. Pics in the first link below
Good luck
Old Mar 31, 2005 | 01:48 PM
1-BAD-C5's Avatar
1-BAD-C5
i was looking at the radom tech x pipes but i think i want to go with no cats i just cant find anything out there, ive heard of dr gas making an x pipe for it but i cant find it anywhere. please any help with this i would appreciate it
Old Mar 31, 2005 | 02:08 PM
ditty22's Avatar
ditty22
ttt for ya! I was trying to find out the same thing a month ago but still dont really know. Im sure someone will chime in though. ditti
Old Mar 31, 2005 | 02:31 PM
1-BAD-C5's Avatar
1-BAD-C5
thanks for the bump, anyone out there that can help please put fourth your .02.
thanks
Old Mar 31, 2005 | 03:42 PM
1-BAD-C5's Avatar
1-BAD-C5
ttt
Old Mar 31, 2005 | 07:47 PM
Face's Avatar
Face
Dr. Gas makes a 3" offroad X-pipe that bolts right up to TPIS headers.
Old Mar 31, 2005 | 09:08 PM
full moon's Avatar
full moon
St. Jude Donor '11-'12-'13-'14
Magnaflow X Pipe.....http://www.corvettegarage.com/produc...-Corvette.html
Old Apr 1, 2005 | 12:11 AM
slammedwhitec5vert's Avatar
slammedwhitec5vert
I Was Looking For The Same Info...tttt
Old Apr 1, 2005 | 04:01 AM
1-BAD-C5's Avatar
1-BAD-C5
2 questions,.. does the magnaflow x pipe fit right up to the 3"collector on the headers and is it a 3" x pipe,..
second question i went to dr gas web site and i could not find the x pipe for the ls1 corvette,... could someone please find me a direct link to the x pipe.
thanks guys
Old Apr 1, 2005 | 01:06 PM
1-BAD-C5's Avatar
1-BAD-C5
ttt
Old Apr 1, 2005 | 09:16 PM
Face's Avatar
Face
thanks guys
You have to call them. And IIRC, MTI also carries it.
Old Apr 2, 2005 | 10:03 AM
1-BAD-C5's Avatar
1-BAD-C5
Thank you i appreciate all the help
Old Apr 2, 2005 | 05:43 PM
joshz06's Avatar
joshz06
http://www.pfyc.com/store/merchant.m...ory_Code=VTEXH
For years, it has been a common belief that all catalytic converters place a choke-hold on performance. In 1993, Random Technology disproved that theory with the introduction of Super High Flow catalytic converters. This design, which meets Federal EPA and California ARB requirements, enables virtually any vehicle with a properly tuned engine to meet emissions standards with little, if any power loss (compared to an exhaust with no catalytic converter).
In fact, Random Technology catalytic converters actually have a higher flow capacity than most mufflers. This direct fit, bolt-in replacement for the stock catalytic converter has a 2.75" inlet and 2.75" outlet.
For those with TPIS headers, select the direct slip fit, bolt-on version built specifically for use with The TPIS Headers. Don't be fooled by others offering a version that requires welding. By the time you pay a shop to weld theirs up to the flange you'll have spent the small amount you saved. In addition it may be difficult to find a shop that will do this work considering the laws regarding catalytic converters. There's no better solution than a direct bolt-on solution.
Independent testing by engine builders, racers, and automotive magazines has repeatedly proven the superiority of the Random Technology Super High Flow design.
To Tpis Headers, What X-pipe Can I Use?
