Installing Z06 sway bars
Old Mar 31, 2005 | 10:44 PM
CUlookin's Avatar
CUlookin
Default Installing Z06 sway bars
Hey guys, I'm installing my Z06 sway bars next week. Is there a detailed thread about this install? Thanks!
Old Mar 31, 2005 | 10:46 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
As Stock man he change his own. I was two lazy and had my dealer due the sway bars
Old Mar 31, 2005 | 10:58 PM
C5 KIDD's Avatar
C5 KIDD
you will love the new bars!!
as far as install... VERY simple! check out the instructions here at ls1howto.com :
Swaybar Install
Old Mar 31, 2005 | 11:12 PM
C5FAST's Avatar
C5FAST
It's really easy. Took me longer to jack the car up than to change the bars. If you have a newer vette with the newer end-links you don't need to use the torx wrench. An 18mm open end and an 18mm deep socket are all you need to get the end links off. And be sure to use lithium grease (or synthetic) not di-electric grease unless you want things to squeak after you are done.
Old Apr 1, 2005 | 12:42 AM
CUlookin's Avatar
CUlookin
thanks Brian, that's exactly what I needed!!
Old Apr 1, 2005 | 06:51 AM
Dark-Knight's Avatar
Dark-Knight
You got the install info above, it is very easy. I have had the Z06 sways for about 6 months, great improvement, noticiably decreased body roll. Just added the Z06 shocks, she is on rails now, very flat in every turn; I do love to take the corners at speed. You might want to check it out.
Old Apr 1, 2005 | 08:02 AM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
Lookin.....as all have said.......It's pretty easy and self explanatory once you get underneath it. The ONLY issue I noticed was a tendency for one of the front mount bolts to try and crossthread. BE CAREFUL of that.
Have fun and you'll love the change
Old Apr 1, 2005 | 11:26 AM
Red Rag Top's Avatar
Red Rag Top
Old Apr 1, 2005 | 11:59 AM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Good luck Rob!
Old Apr 1, 2005 | 12:49 PM
bernardomd's Avatar
bernardomd
I'd also like to upgrade the suspension in my 97 coupe. Does it make sense to upgrade everything at the same time (springs, shocks, and sway bars)? Anything else I should do?
Plus, which parts are best? Z51? Z06? Bilstein? hotchkins? There's so many options!!! Anyone with a lot of experience want to make some recommendations? I simply want better performance and I can handle a stiff suspension, but I don't want it to be too harsh. When I go over any kind of dip while driving fast, the car seems to hit, almost like the springs are too soft.
To Installing Z06 sway bars
