if basically stock
performance to me is just before rev limiter hits 6200-6400
and for economy-if you kept in the cags..1st to 20mph with a light foot and directly to 4th and easy as you can be ,on up-driving around like that you would probably get 22-24mph-
but then forget performance-the computer would be so confused the car would probably run like sh^&#,for about 5 hard runs..so what did you gain
around town i get 18 mpg if i run it hard alot about 17 mph
and hwy i get 24-26..why have the z if i'm gonna drive it 1/2 throttle all the time?? gas just hit $2.69 / gal in wonderful kaleforneia
I always shift at 3k rpm.. on normal driving. the engine isnt really working at that point, but anyhow, I shift then, all the way up to 5th or 6th gear depending on how fast I want to go. If you stay around 3k you get decent milage.
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
REV LIMITER is set on a stock Z at 6600, so for optimal ***** out performance, racing, etc., you want to shift as high as you can without hitting the rev limiter (that being 6400 rpms) or 6500 if your a REAL PRO!!!!!!!!!!!!!
I Think 6400-6500 on the 1-2 & 2-3, but at 6300RPMs on the 3-4. Every time I shift the 3-4 at 6500 my MPH is reduced. Of 8 runs last night the slowest MPH was shifting at 6500, which it always the case when I shift late. At the 3-4 it doesn't cost you much, but I'll take anything I can get.
Here was the lowest MPH of the night, which had started out my best 1/8 mile MPH.
60' ... 1.665 (6500RPMs@ 3-4)
330... 4.786
1/8...7.395
Mph...96.50
1000...9.658
1/4...11.575
MPH...117.40
I can't say this run alone concludes much, but it doesn't seem to hurt shifting earlier either. I came to this conclusion after months of analyzing simular runs with different shift points. Not saying it's best for all, but it's working for me at this time. After I get a tune this year and raise my Rev limiter, I may try the 6700 range to see what happens.
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
330... 4.786
1/8...7.395
Mph...96.50
1000...9.658
1/4...11.575
MPH...117.40
Once again, nice runs bro! What rpm were you launching at?
Based on the 2 run comparison you posted, I'd rather get a lower ET shifting higher than a higher ET to get a slightly higher MPH, no?
Ron
My experience is that the best times are produced shifting at as high an rpm as possible without kissing or slamming the (6600) rev limiter. The reason that produces best ETs is because each shift will give the most torque AFTER the shift is completed and the pull begins in the next gear. More torque at 4500 than 4200-4300.
The benefit of keeping an MSExcel log of all your passes, the splits, and the incrementals between the splits, is that you learn what factors produce the fastest times. Shift points are certainly key.
Do you guys feel a shift light would be a good purchase to keep off the rev limiter and in the groove for speed?
I don't use one; but some folks, especially bracket racers, find a shiftlight helps keep them off the limiter, and gives better consistency. Others simply raise the limiter a few hundred via LS1-edit or similar PCM tuning tools.
Ron
Thanks Dr.Ron, launch was at 5000-5500 RPMs.
Notice I was down .035 at the 330. That's why the time was slower. First run took me 4.18 seconds and a gain of 20.9 Mph from the 1/8 to the 1/4. Second run took me 4.159 seconds and a gain of 22.59 Mph. I almost made up the diff by the 1/4 mile mark. So, I think I would have ran faster on my first run if I had shifted sooner on the 3-4. Ranger , I have logged 60+ runs on excel with times of 11.40-11.69 just to compare differences. But, I'm not saying it's fact, it's just what my analysis keeps pointing too. It does make all the since in the world to shift at 6500 RPMs at the 3-4. But, I continue to see lower MPHs and a slightly slower times from a 6500 shift. Heck , just try it out for fun and see what happens.
Thanks for the details, I appreciate that. Are u powershifting?
Yes, which brings up another point to why I might be running slower shifting at 6500 RPMs. With powershifting I'm sure I actually go over during the shift which guess what happens at 6500+ RPMs........Fuel cutoff occurs. So, what I need to know is if you guys saw any gains at 6600 or 6700 Rpms who have had the rev limiter raised.
Yes, which brings up another point to why I might be running slower shifting at 6500 RPMs. With powershifting I'm sure I actually go over during the shift, which guess what happens at 6500+ RPMs........Fuel cutoff occurs. So, what I need to know is if you guys saw any gains at 6600 or 6700 Rpms who have had the rev limiter raised.
