[Z06] 01 zo6 questions...
Old Apr 2, 2005 | 03:33 PM
Jeffs FRC's Avatar
Jeffs FRC
Default 01 zo6 questions...
My friend is looking at an '01 speedway white/mod red zo6 with 25k on the clock. He really likes the car but is afraid of the oil consumption issue. Are all 01's affected or just the early production cars? The car was manufactured in april of 01. Any help would be great!
Jeff
Old Apr 2, 2005 | 03:55 PM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
For a White w/ mod red interior I would take my chances. By far the best looking Z offered as well as the rarest.
Have to spoken to the previous owner to see if the re-ring was performed or if in fact it ever burned oil?
Old Apr 2, 2005 | 04:21 PM
Jeffs FRC's Avatar
Jeffs FRC
Cant speek to previous owner because its at a dealer.
Old Apr 2, 2005 | 05:34 PM
mdhmi's Avatar
mdhmi
I was having a bit of an oil consumption issue until I installed a PCV catch can ($90) and a Metco valve cover breather ($50). The oil consumption issue risk can be mitigated, per above - at least in my experience.
Good Luck,
Mark
Old Apr 2, 2005 | 06:11 PM
ModRed405's Avatar
ModRed405
If the price is right, jump on it like ya got pocket Aces!
Old Apr 2, 2005 | 07:16 PM
1320IN9's Avatar
1320IN9
go for it, if its clean, and runs good, so what if it needs a 1/2 qourt of oil in between changes, i have heard of 02-04 that use oil, run the vin at a chevy dealer to see what kind of service it has had in the past
Old Apr 3, 2005 | 12:20 PM
RICHARD D. HUDSON SR's Avatar
Jeff I Have A Sw. White With Mod/red . Also Had The Oil Consumption Issue. Buy The Z If It Is Clean. Imo.
You Can Start With Visit To A Gm. Dealer With Vin No.
Of Z A Get Service History Of The Z . Then Call Gm. Customer Service. Refer To Technical Service Bulletin
Number ( 01-06-01-023a) & Request A Oil Consumption Test Be Started The Z. If You Need More Info. Pm. Me
Phone No. I Will You Info. If I Can . Good Luck
Old Apr 3, 2005 | 11:01 PM
Black01Z's Avatar
Black01Z
buy it if u can get a warranty. cause to get the re-ring done if it needs it- and some will go through a quart every 500 miles- is expensive!!!
Old Apr 3, 2005 | 11:27 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Jeffs FRC -
As has previously been stated, have the dealership print out the service history - or at least bring the history up on the computer for your friend to review -
Check for the re-ring. If it has not had it done, the car may not have had an issue.
As an aside, they only made white Z06's in 2001, and there were very few made - less than 300 - and even less with the beautiful (IMO) mod red interior.
best regards -
mqqn
To 01 zo6 questions...
