t1 suspesion
Old Apr 2, 2005 | 05:23 PM
KillerJello's Avatar
KillerJello
Default t1 suspesion
Who here has the full T1 setup?
do you like it? how much difference than stock does it feel?
thanks
Old Apr 2, 2005 | 05:27 PM
AU N EGL's Avatar
AU N EGL
I have a full t1.
There are several threads about the t1. for street driving rocks would be softer. The T1 is a road racing suppnesion and not for street use.
http://forums.corvetteforum.com/show....php?t=1053223
Old Apr 2, 2005 | 07:10 PM
Z06machine's Avatar
Z06machine
Coupe or Zo6?
Zo6 - Try the T1 Sway bars first. It gets pretty stiff with these alone.
Feels more solid on the track.
Not much difference in the Sachs T1 shocks and the 04 shocks
on the street.
The Springs are another story. Stiffer and more bounce to the ride
but carve corners like mad.
Coupe - Try the Hotchkiss bars, noticable difference at a reasonable cost.
Old Apr 3, 2005 | 04:45 AM
KillerJello
coupe
why would it matter one way or the other???
with a coupe or a z06?
if you upgraded to a full t1 on a coupe it would handle better then a zo6
i thought the only difference between the two was the shocks, springs, sway bars, and that is i think ( i might be leaving something out)
thanks, Scott
Old Apr 3, 2005 | 06:21 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Answers are here
http://www.jakelatham.com/c5/misc/faq.shtml#2-3
EG
Old Apr 3, 2005 | 09:17 AM
AU N EGL's Avatar
AU N EGL
Originally Posted by KillerJello
coupe
thanks, Scott
T1 Spring are much stiffer, sway bars much thicker, and shocks are stiffer then the Z06 plus there are the polyurathain bushings and the T1 negative camber ecentrics. all these make for extream stiblity with minimal body roll on high speed cornering
I have driven several coupes with 04 zo6 suppneions and equal hp. I felt the coupe handle better and I think it is the aerodynamics advange of the coupe vs the FRC design of the Z06.
again the question is, What are you going to use your car for?? the T1 is not comfortble for street driving, but hell on wheels for DEs or road racing. But then again on very bumpy road race circutes like Summit Point WV the ZO6 suppension works better as it has a little more give and compliance going over bumpskeeping the tires on the pavement and not bouncing with a very stiff T1 suppension.
Suppensions are designed to work as complete package, not piece meal.
Old Apr 3, 2005 | 02:06 PM
leaftye's Avatar
leaftye
Just one thing...it's not polyurethane bushings, it's a higher durometer (read "harder") rubber....unless something has changed.
Old Apr 3, 2005 | 11:49 PM
KillerJello
Thank you
Scott
To t1 suspesion
