Broadcast sheet
Old Apr 3, 2005 | 07:49 PM
5JTL's Avatar
5JTL
Default Broadcast sheet
Where is the assembly broadcast sheet loacated in an '04 coupe and how do you go about retreving it? I'd like to file it with my other documents.
Thanks.
Old Apr 3, 2005 | 07:51 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
I believe the build sheet is in the front of the frame, and that you have to remove the front facia to get at it. Could we interest you in a copy from the Corvette Muesum for your record?
Old Apr 3, 2005 | 07:56 PM
5JTL's Avatar
5JTL
Sounds like a solution. Let me know the details.
Old Apr 3, 2005 | 08:19 PM
ptdrummer54
CI 5-6-7-8 Veteran
NCM Ambassador
https://www.corvettemuseum.com/libra...ts/index.shtml
Old Apr 4, 2005 | 06:15 PM
The build sheet is in the front frame behind the fascia. Its easier to just order a copy from the Corvette Museum.
To Broadcast sheet
