Is this normal?
Old Apr 4, 2005 | 12:01 AM
SphyNxXx's Avatar
SphyNxXx
Default Is this normal?
I have a basically stock C5 (a4 with 3.15s) and stock runflats. The only mods on it that I know of are cold air screen and maybe a 180* tstat. Tonight, I put it in competitive driving mode and took it on an empty stretch of road up to 30mph. I floored it at 30mph and the car got all squirley and the back end even moved over onto the other lane and I had to let off to keep control of the car. My g/f in the passenger seat was nearly paralyzed by it Is this normal for a stock C5? I had a 01 Z28 (a4 with 2.73)j with muffler, lid, predator, and a free mod and it wouldn't even come close to doing that. Heck, sometimes I would even hook up with little effort from a dig. Could it be possible the original owner tossed a set of gears in it and I dont know about it? The car came from Carmax and it was shipped from several hunderd miles out of state, so I know nothing about the previous owner other than the car was taken really good care of (near perfect shape minus a couple touched up rock chips and 14,100 miles on the clock for a 98 ).
Old Apr 4, 2005 | 12:04 AM
ALLEGRO's Avatar
ALLEGRO
It depends on traction conditions.
You have a lot of HP and Torque so just be prepared.
THAT IS WHY ... they have TC as the default setting. Just to keep you out of trouble.
Have Fun
Old Apr 4, 2005 | 12:14 AM
SphyNxXx's Avatar
SphyNxXx
Have Fun
Wierd thing is, Ive been in a car with 300+ ft/lb or torque since Oct. of 2001. My Z dynoed 303rwhp, 324ft/lb before I got the C5, and it didn't come close to doing this.
edit....my tire pressure is around 34-35psi due to losing pressure during winter....maybe that is part of it, but I have had a lot of traction issues, especially lately. It was around 60* outside and dry tonight when I did this.
Old Apr 4, 2005 | 12:20 AM
Cajun99's Avatar
Cajun99
Mine's squirrely through the first three gears...wouldn't have it any other way. God Bless the Six-Speed and 3.42
I always leave the TC off as it gets in my way too much when I want to have fun. I like using the power to move the car the way I want it to...without the TC making it fall on it's face.
Leave your runflats at 30psi cold. They're slippery enough without compounding the issue with higher pressures.
Old Apr 4, 2005 | 12:23 AM
SphyNxXx's Avatar
SphyNxXx
Grettings from central Alabama Live in Clanton, commute to school at AUM in Montgomery.
Old Apr 4, 2005 | 12:38 AM
Cajun99's Avatar
Cajun99
Mobile here...I only get to commute to work
You couldn't pick a better car for the ride to school!!
Old Apr 4, 2005 | 01:04 AM
Tarkdog's Avatar
Tarkdog
I got a 6 spd and I get the same results as you guys These cars are friggin awsome
Old Apr 4, 2005 | 01:11 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
I'll bet it's the tire pressure. And if they are runflats that are more than 50% gone that will contribute to it.
Old Apr 4, 2005 | 01:49 AM
SphyNxXx's Avatar
SphyNxXx
Yes, they are the runflats that came on the car when it was new (I assume). They have around 28K miles on it, mostly highway.
Old Apr 4, 2005 | 02:10 AM
B R's Avatar
B R
From: Los Angeles, CA.... I know a guy who has a Lambo with Corvette doors
And how much did your z weigh ?
Old Apr 4, 2005 | 07:09 AM
Dark-Knight's Avatar
Dark-Knight
Weight/power ratio makes all the difference. The C5 is a awsome ride and demands respect. If you switch off any computer assists beware!
Old Apr 4, 2005 | 07:14 AM
LuS1fer's Avatar
LuS1fer
Gears and weight are the difference. My Z28 has 2.73's and even on a full-boot will only squat and go but the auto only has the choice of two gears - 2nd or 3rd. My Z06 will skip sideways even with everything switched on, let alone competitive driving. Less weight and more rigidity means the power goes to the road not into twisting the chassis.
Old Apr 4, 2005 | 07:16 AM
Check your tread depth on the tires. If it is getting low, that could be part of your problem.
Old Apr 4, 2005 | 09:36 AM
Mr. Jones's Avatar
Mr. Jones
35-36 pressure and its down from the winter temps?
try 30lb cold and check tire accross the entire contact area.
do not just look at the outer edge. many people just look at the edge, if the alignment is out the tires can wear uneven.
Old Apr 4, 2005 | 11:22 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have the same problem, to much power, have to write GM about this
Old Apr 4, 2005 | 11:35 AM
byte_me's Avatar
byte_me
My 97 Auto with Z51 and 3:15 gears does this as well, and my run flats are pretty new...try doing that around a corner from say a stop...I did- and that big *** hops out like crazy when 2nd gear comes out!
Yes- there is a LOT of power and torque being generated back there...be careful- and have fun with it! :-)
Old Apr 4, 2005 | 11:48 AM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
If you had a 273 in your vette, like you did in your camaro...you probably would not have had this happen either in the vette. Lots of factors come in to play..outside temp, tire PSI...you mention you had 35 or 36 PSI I think at the time? actually , cold I think the runflats should be at 30..if you drop your PSI that will help a little with traction...be careful
To Is this normal?
Old Apr 4, 2005 | 12:00 PM
SphyNxXx's Avatar
SphyNxXx
3400-3500lbs....light enough to run 13.30s to 13.50s @ 104-106mph
Im going now to drop some pressure off the tires.
Old Apr 4, 2005 | 12:28 PM
90 droptop's Avatar
90 droptop
Hhhmmmmmmm, the cars in my sig don't behave that "scary". Maybe you need to countersteer a little bit.
Old Apr 4, 2005 | 12:39 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
Yes, it is normal to paralyze women passengers while doing the squirley back end...
